Question about LG Washing Machines
Hi. I have a 2nd hand WD8016C LG but dont know which compartment is pre wash, wash + fabric softener. Also, bubbles form at the window and stay at the end Thankyou
  • LG Master
  • 2,374 Answers
First compartment on right side of drawer is prewash, next to it on the left is wash, second compartment on right is softener. Bubbles because you are using far too much detergent. Only use 2 tablespoons max for normal fairly large wash load, even less for smaller loads. Front loaders use little water, so need much less detergent. Also, highly suggest you not use softener, leaves residue in washer that soon turns to mildew and bad odors. Use white vinegar in its place. Helps remove detergent residue from clothes, keeps tub smelling good, and is very inexpensive. Liquid detergent is also an issue--it too leaves residue behind. Powdered detergent works much better and also is cheaper(counterintuitive you would think liquid dissolves better, but it doesn't).
Posted on Dec 17, 2016
  • 4 Answers
SOURCE: Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
SallyUK
  • 9 Answers
SOURCE: which compartment does my detergent/fabric softener go in?
You can get all of Whirlpools user guides here:
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001/ifu/home Generally the one one the left - is for pre-wash (if clothes really soiled), the middle one is for powder (if you use it) and the last one is for softener or bleach.
I just use liquitabs - which go directly into the drum, and fabric softender.
Posted on Jun 16, 2009
SOURCE: MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Posted on Dec 08, 2009
SOURCE: Fabric softener compartment blocked
The fabric softener section in the drawer on my washing must be blocked as the fabric softener is staying in the drawer. Does anyone know any way to unblock it
Posted on Nov 06, 2010
  • 6277 Answers
SOURCE: Fabric softener compartment won't drain. How can I
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 22, 2011
How to replace blue fabric softener dispenser? Came out easily but cannot replace it. Thank You LG WT1101CW
SOURCE:Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Mar 23, 2018 | LG Washing Machines
Fabric Softener Does Not Drain
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
25569074-ineink0kisfnom0atbkujjcx-3-1.jpg 25569074-ineink0kisfnom0atbkujjcx-3-3.jpg 25569074-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Mar 14, 2015 | Ariston Technologies AW125NA 13 lbs. Load...
I have an AEG 72640. It is taking the fabric conditioner in the 2nd rinse instead of the last and the clothes are not coming out smelling of fabric conditioner. How can I solve this?
Hi. The problem will be one or more of the holes in the top of the soap dispensor (view with drawer out) will be partially blocked causing water to squirt into to one side and fill softener compartment. Dont overfill with softener stay below max level. Holes are not easy to unblock use large paper clip ,bent to allow you to poke holes clear.
Jun 21, 2012 | AEG Lavamat 72640 Front Load Washer
I'd like to know which soket is for bleach fluid, which for washing liquid, and which for soften liquid? thanks.
The First Compartment Is For Fabric Softener The Second Is For Main Wash Detergent The Third Is For Pre-Wash Detergent.
Sep 18, 2011 | Washing Machines
Lost manual to LG washing machine WF-T502c Fuzzy Logic. Just want to know where detergent and softener go?
I do not know this model. However, on other top load LG washers, the powdered detergent goes in a box at the back (top) of the washer, and the fabric softener when diluted gets poured into a spot near the left side of the top of the washer. (The bleach goes near the front of the washer.) For front-loading washers, the detergent and fabric softener are poured into the detergent drawer. The largest compartment is for detergent (wash cycle) and is usually on the left. The smallest compartment is for fabric softener.
Manuals for most LG appliances are available at their site. Start at http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WF-T502C&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WF-T502C&initialTab=documents&targetPage=support-product-profile . The manual is in a DjVu format.
A partial manual is also available here: http://monitor.diplo-best.com/review/LG/WF-T502C . You will need to review the washer or enter a code.
I hope this helps.
Jun 13, 2011 | Washing Machines
I own a lg fully automatic washing machine front loader (model:WD-8074FHB)i dont have an owners manual. My question: There are 3 sections. 1st section is for washing detergent. Which of the other 2 are...
Hi Anna, As you face the machine the left section of the draw is for the main load washing powder, the middle section is for fabric softener and the right section is for the pre wash powde.
Hope this helped :-)
May 21, 2010 | Washing Machines
Which compartment does my detergent/fabric softener go in?
Jun 16, 2009 | LG WD-16110FD Front Load Washer
Which comaprtment for the washing liquid ?
Compartment 1 is for Pre Wash
Compartment 2 is for Main Wash
Compartment marked with what looks like a star is for conditioner.
Bosch manuals can be downloaded from www.bosch-home.co.uk
May 19, 2009 | Bosch Dryers
May 01, 2009 | Bosch Washing Machines
LG wm-2277hw
If yours is the same problem, water in the dispenser, then the answer is the same...
The reason there is still water in the dispenser, and this in normal by the way, is the unit uses the pre wash and main wash valve to activate the fabric softener. Basically when the two valves come on they force water into the fabric softener compartment. There can be some overflow and it ends up in the blue cup nothing to worry about. Now if you have detergent there, then that is a problem..
Sgt 48
Jun 13, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
