Question about HP Compaq WF1907 Monitor
Computer beeps when I turn it on and keeps beeping the monitor
Says it is sleeping I have not been able to get a windows start up at all.
  • 130 Answers
Take your memory out and reseat it otherwords
put back in make sure its in all the way
Posted on Jul 20, 2009
Beep codes errors
This maybe a RAM problem and the video uses shared (main) memory.
Try reseating the memory modules, if this does not fix the problem then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM module/s for you.
Jul 25, 2012 | HP Pavilion Computers & Internet
Computer won't start, solid amber light, no fans, no keyboard, nothing. There is power to monitor and modem. What's wrong and how can I fix it?
That my Friend is the Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, during a power outage with no surge protected, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Sep 21, 2010 | Dell Inspiron 530 Desktop Computer
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
I have a blank screen on my HPf1905 monitor. I have a HPm7330n computer. How do I know if its the monitor or the video card? Monitor shows a message no input signal,then goes to sleep mode.
if the message you recieve is no input signal if only means that you have a problem with your video card, the monitor is fine but you need to have your video card check
Nov 21, 2009 | Computers & Internet
Monitor is in sleep mode and I here a beep periodically
Try change the keyboard, if the pc does not detect the keyboard or a key from the key board is stuck which gives something like tic tic sound. On the other hand the display from monitor "sleeping mode" indicates the VGA cord is faulty or monitor is no compatible to the PC's video card.
Nov 26, 2008 | HP Computers & Internet
Try to start my computer but tower keeps on beeping and monitor keeps saying going to sleep. What could be the problem?
Probable reason for the beeping sound are:
  • defective, dirty or faulty seated memory sticks; clean, re-seat or replace (most likely);
  • defective, dirty or faulty seated video card; clean, re-seat or replace (likely);
  • corrupted BIOS; flash or replace motherboard (least likely).
The monitor going into sleep mode is because it does not sense any usable video signal from the computer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Computers & Internet
It wont boot up
The power supply unit is bad. You will have to replace it. Also, it is custom specific ~ write down the specs of the PSU and order it from legendsmicro.com. This recently happened to me.
Oct 12, 2008 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Going to Sleep Displayed
I turned on my computer and the monitor displayed this message on the screen "going to sleep no input received". I checked the power cord and unplugged it, nothing. No lights are flashing or beeping sounds. The CPU is working just fine, anyone have any idea what to do
Aug 02, 2008 | HP vs19 (Silver) 19" LCD Monitor
Stuck in sleep mode
Press the power button on the Computer it should come out of sleep mode then if it doesn't hold the power button of the computer down until the system turns completely off.
Then turn back on the computer should now boot fine. Once in windows goto control panel and select power option then adjust the setting.
Hope this helps you
Cheers J
Jan 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
HP Compaq WF1907 Monitor Logo
144 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
