How to stop play and eject disc from Finch LE2230DVD. No eject or stop button on remote.
  • 97 Answers
SOURCE: Cannot play or eject disc
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
Posted on Jun 11, 2007
  • 3 Answers
SOURCE: Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Posted on Oct 16, 2007
  • 223 Answers
SOURCE: stuck cd discs
I think there are a couple of faults here. The first one is maybe a faulty motor on the eject mechanism. The second one is a faulty laser unit as it is not scanning the disc. Hope this helps.
Posted on Oct 05, 2008
elecgooroo
  • 57 Answers
SOURCE: tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Posted on Jan 11, 2009
SOURCE: Disc won't eject
the disc on the drive cannot eject.how can i fix it?
Posted on Apr 29, 2009
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
How can a TRA OFF my HTS7140? or how can I eject the disc that is in it?
Keep 'Stop' button on remote control pressed for 3-4 seconds and your disc will be ejected.
Press 'Play' button to 'eat' disc again.
Apr 03, 2011 | Philips Audio Players & Recorders
My sony dvd player will not allow the tray to eject. when the eject button is presses "tray locked" appears on the screen
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control. NOTES:
If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode. Each time this procedure is performed the disc tray will either lock or unlock.
Jan 02, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Will not read disc or eject disc
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Power botton not responding
If it's not ejecting or responding to any of the buttons on the unit, or the remote, but is able to play a DVD, the display microprocessor(computer) within your Harman is damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 22, 2008 | Harman Multimedia HS 300 System
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Soundspace 8 - Disc eject / play problem
Hi Kev Frey, Have you checked the mechanism for a broken or loose belting or possibly a broken gear teething. With Regards, Edmund
Aug 13, 2007 | Nakamichi SoundSpace 8 CD Player
Dvd-r problems
Unplug your AC power cord for a minimum of 30 seconds to clear the RAM. The RAM is used solely for dvd class history, and clearing this should solve your issue. If you want to convert your player to region free, which will allow you to play ANY dvd: 1 Disconnect your player from its power source for thirty seconds 2) Reconnect your player to its power source 3) Press the Power On button on your remote control 4) Press the Enter button on your remote control 5) Press the 8 button on your remote control 6 Press the 4 button on your remote control 7) Press the 2 button on your remote control 8) Press the 6 button on your remote control 9) Press the 9 button on your remote control 10)Press the Enter button on your remote control 11)Your player should now place itself in Standby mode 12)Press the Power On button on your remote control A word of caution if your convert your player is that disc eject issues may arise in which you will have to eject from the unit, or toggle your power switch on/off.....good luck my friend.
May 16, 2007 | Samsung HT-DB120 System
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
