Question about Hotpoint Refrigerators
My hotpoint rfa16 future has defrosted itself and now doesn't seem to be freezing now. Im not sure if the fridge part is still working as I only discovered it when I came down this morning.
    Top Expert:
  • Hotpoint Master
  • 49,159 Answers
Refrigerators work from the freezer . if the freezer is OK then it has to be the air damper causing the problem , call a repair technician . I have heard of some that because of how they put the wiring thru they can not be fixed .
Posted on Dec 16, 2016
Hotpoint rla31 motor constantly running/freezing at the back
Your fridge is cooled by the freezer, the thermostat is within the Fridge to tell it to shut off, you might have a bad fan or a build up of frost where the air is sent to the fridge, check where air goes to the fridge when it's running, if you don't feel air flow then something is up, best thing you can do is take everything out and allow the fridge to defrost, at leat 24hrs. then see what happens, if you don't feel air flow after the defrost then you fan is shot and you'll need to replace it.
Aug 04, 2012 | Hotpoint RLA31 Compact Refrigerator
I have frost free hotpoint future,the fridge seems to be working but the freezer isnt at the minute, the food is not freezing and the fan does not seem to be working! it has no suction on doors either, my...
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 15, 2010 | Refrigerators
Temperatures not staying cold, then getting too cold. First everything in freezer thawed out. Then, fridge wasn't cold enough. We moved everything to freezer just to keep colder (not to freeze). Then, days...
assuming fan now working. clean out vents/ drain holes (make sure no ice in bottom of freezer or in fridge unit)i.e. a total defrost.then check door seals all okay(no air leaks) if unit was trying to defrost itself and you reset to colder it will need to reset itself.....
Feb 11, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer has defrosted itself fridge still seems to b workin but warnin light for freezer temp is on? Iv tried the fast freeze but it hasnt worked
is this a manual type unit or just a chest type freezer if just a freezer as soon as it reaches a temp of 08 the alarm should stop
Aug 19, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Sid By Side Freezer Icing and Fridge not Cold
most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Jun 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Hotpoint rfa18 Fridge Freezer
Is the back wall full of frost? If so you have a defrost problem, most likely the defrost is stuck in the run mode. this is located above the controls area in the fridge.
Nov 14, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Pop full of ice
Sandy, this sounds like a bad thermostat. First: does the unit seem to run continuously? Try this: turn the stat to a position near 'off'. Does the compressor turn off? If not: change the stat. Before you do: check the position of the thermostat bulb. On some units, you can see a thick silvery 'wire' coming out of the thermostat housing. It should be fairly straight and generally located near an air duct inside the unit. If it has become dislodged, put it back. If it is broken or kinked, it needs to be changed. Be sure to unplug your fridge before working on this!
Other possible problems: You may have either low gas or a bad defrost timer. Low gas generally will show up as frost on one side of your freezer compartment and airflow will be fairly low when the fan is running. The defrost timer, used to schedule a defrost cycle is generally not a big problem on GE/Hotpoints, though.
Nov 25, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint future RFA60 Fidge Freezer
I have lost the instruction booklet for my Fridge Freezer RFA60. How do I defrost the freezer?
Nov 04, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
43 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
