Question about Ovens
I have a dyson am08 fan. it stopped working & it displays the fault code F3. what does F3 mean & what should i do?
I want answers for the am08 ONLY. i do not want answers for any product that is not a fan.
  • 331 Answers
SOURCE: F3 Fault
Either your new temp probe failed or there is a wiring problem between the probe and the electronic relay control.
Posted on Jul 30, 2007
  • 4889 Answers
SOURCE: F3 Error
This is due to a Defective control board..You have to get it replaced..
Posted on Oct 22, 2007
  • 16 Answers
SOURCE: GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
shorted touch pad(memberant)becareful remove ribbon cable clean and reseat you can test the touch pad alot of the touch pad failed because the heat(poor design cheap make)
Posted on Mar 12, 2009
  • 1723 Answers
SOURCE: Kenmore Model 665 95781000 Stove Displays a EO-F3
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Posted on Sep 26, 2009
  • 464 Answers
SOURCE: what does e1 f3 fault code on my oven mean
F3 means your oven temperature sensor is open. you will need to get it replaced. hope this helps.
Posted on Oct 15, 2009
F3 code
I don't think in is unsafe to operate. I worked with boilers that used igniters and a temperature sensors. Usually what these codes mean is (simply error codes ) to guide you which part/s does not function or respond correctly or within a certain time in seconds and brings up this code, but if you get it to ignite, use it like that until you can get someone to do some maintenance on it. Just remember, if your heat is not at the correct temperature, your igniter will fire, but will not be able to ignite the flame.
Meybe lookat this video will make you understand better.
Apr 29, 2014 | Ovens
My oven giving f1 f3
The F3 error code means that the oven temperature sensor is shorted and not telling the oven control what the temp. is in the oven. Check out this tip i wrote about what to check when the F3(and F4) is displayed
Oct 21, 2011 | Ovens
What does F 03 on the display mean (my oven is not working)
Most Whirlpool ovens and F3 code is a failed temp sensor.
See this link:
and this one:
An oven too HOT indication is also F3 but the cause is still a failed temp sensor.
Thanks for choosing FixYa,
Sep 23, 2011 | Whirlpool Ovens
Fault codes F1 and F2
Just two work there:
1.- Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
2.- Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Parts replacement coudl look in
Hope helps.
May 02, 2011 | Magic Chef Ovens
My oven works sometimes and not others. I continue to get F3 code displayed, but can't figure out what it means. I have done everyting the manual says to do.
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that should help Fault Code F1 F3 F9 Dr. If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Dec 31, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
What does f3 mag mean on the display?
F3: Magnetron Current Low
Fault is displayed when the current transformer
(CT) on the I/O control board does not detect
enough current. The fault is monitored when the
microwave is on during a cook cycle or self-test.
The fault is cleared from the display at the onset of
a cook cycle if the CT detects current or when the
magnetron is successfully energized in Test Mode
Sep 03, 2010 | TurboChef TORNADO Electric Oven
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Kenmore Model 665 95781000 Stove Displays a EO-F3 code and the oven does not work WHat part work be defective to give me this fault code EO-F3?
Sep 25, 2009 | Ovens
F3 is Open oven temperature sensor circuit.
F4 Shorted oven temperature sensor circuit .
F7 Component failure.
To fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Oct 28, 2008 | GE JRP15 Electric Single Oven
Error codes
Hello raco1
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
23 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
