Question about The Audio Players & Recorders
I lost the sat speaker how can i make it work the model hk 695
4 Suggested Answers
SOURCE: Open the HK 695 Audio System Satellite speaker
Open the satellite speaker's metal mesh with a steel needle. then u will find the inside screws to open it.
Posted on Feb 11, 2011
mikeywaf
  • 346 Answers
SOURCE: What is the fuse size
Greetings - You need a Radio Shack 270-1062 3/4 amp slow blow fuse or equivalent. Any .75-1 amp fuse of the same size should work fine.
Regards and Good Luck.
Thanks for using Fix Ya.
Mikeywaf
Posted on May 01, 2011
undernet01
  • 492 Answers
SOURCE: very low volume HK 695-01
There are several ways in which you can increase the volume.
First, the most obvious way is to use the volume control attached to the speaker unit itself. If that isn't working, there's also an icon in the lower right-hand portion of the task bar in Windows. Simply click the ^ button, select the icon that looks like a speaker, then drag that up to your desired preference.
If that doesn't work, click on Start, go to Control Panel, click on Sound, then search for your Speakers in the "Playback" tab. First, make sure it's set as your Default Device. There should be a green check mark in it. Double click on those, select Levels, then make sure Play Control is set to maximum.
If that doesn't work, then check the settings on your Sound Card. Make sure the wire going into the back is plugged in properly. You may need to update your sound card drivers. If you aren't sure who the manufacturer of your sound card is, you can find out by going to Start > Control Panel > Device Manager. The Manufacturer will be under Sound, Video and Game Controllers.
Once you have that information, you can go to the Manufacturer's website and update the Drivers. If this doesn't resolve the issue you are experiencing, or if you require more specific / additional information, simply respond to this thread. I'll be happy to assist you further.
Regards,
Aaron Busch
Senior Tech of LiveFix Support Services (LiveFix.net)
Posted on May 03, 2011
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
Connecting 4 ohm speakers
I don't think it has anything to do with the impedance. The amp and speakers are well in the allowed limits. The only time this is a problem is if you connect an amp with a greater impedance then the speakers.
This sounds like something to do with the HK 990. It could have a fault on it. You could try listening with headphones if the HK 990 has a socket for them. If they have low sound, there's an electrical fault in the power amp of the HK 990.
Jun 09, 2012 | Harman Kardon Harman HK 990 Amplifier
How are you? For HK990,How to do bi-wiring connection of the speakers? thanks
Sabve your money - it's BUY-wiring.
http://www.harmankardon.com/EN-US/Products/Pages/ProductDetails.aspx?PID=HK+990
http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/HK%20990_OM.pdf
Bi-wiring does nothing but make you use twice as much speaker wire for the same electrical effect. Bi-amping assumes there are deficiencies in your electronics that must be worked around, again by using more speaker wire and separate amps.
Do some reading on the web about "bi-wiring".
Jul 16, 2011 | Harman Kardon Harman HK 990 Amplifier
Very low volume HK 695-01
Regards,
Aaron Busch
May 03, 2011 | Harman Kardon HK695 Computer Speakers
What is the fuse size ( I know voltages but not proper ampage) for thr Harman/Kardon hk 695? Thank you
Mikeywaf
May 01, 2011 | Harman Kardon HK695 Computer Speakers
Oct 01, 2009 | Harman Kardon Audio Players & Recorders
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Dec 28, 2008 | Harman Kardon HK695 Computer Speakers
46 people viewed this question
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
JOHN TOPLISS
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
