My laptop randomly disconnects from wifi - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 26,637 Answers
Try downloading updated drivers from the manufacturers web site NOT microsofts generic drivers.
Posted on Dec 16, 2016
Hp 560 wifi button not working
MAYBE THIS LINK WILL HELP YOU SOVE YOUR ISSUE: http://www8.hp.com/h20195/v2/GetPDF.aspx/c04229561.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/lynn_f08552ff80c75888
Apr 15, 2015 | HP Computers & Internet
We recently upgraded our iphones. Since then we are having truoble with our internet connection randomly disconnecting some of the devices being used.
If the WIFI security encryption for the WIFI password isn't in what's called "WPA2-ONLY", sometimes there will be random disconnects. By default, I think the encryption is "WPA+WPA2 mix mode" which can be the source of disconnects.
You will find this in your router's settings which you can access by navigating to what's called the default gateway IP in any web browser. Commonly, it is 192.168.0.1, but can be 192.168.1.1, or even 192.168.2.1. It will ask you for a username and password if you've done it correctly. It might say on the router what the username and password is, or you can find the default login credentials online for all common routers.
Login, then find some kind of "security" tab, maybe under wireless, or WLAN, or something like that. It will give you an encryption option for the wireless network and password, and choose the WPA2-ONLY option. Save or apply the settings, and your router will reset and hopefully you won't have any more disconnect issues.
Dec 17, 2013 | NetGear WNDR3300 - RangeMax Dual Band...
Phone makes a loud irritating sound when the phone loses a wifi signal
you have to go sound setting and off your wifi sound by manually
May 20, 2017 | Blu Cell Phones
Wifi problems v3-771
Inside most laptops, there is a WiFi Antenna. I once also had an issue with my laptop allowing me access, and then flicking off again. So every time I tried to use a program called "Steam" I would be disconnected from the servers. Inside the laptop, there is a wire that is attached to the WiFi receiver, that gets plugged into your laptops motherboard, If it is loose, just disconnect it completely, then plug it back in. If the antenna is warm, or hot. That means it is burnt out, and will continue not to work unless it is properly cooled. You CANNOT cool a WiFi antenna, so it is best to either search the web, and buy a new WiFi antenna that is the same model and brand as the one in your laptop, or just buy a LAN/Ethernet cable and play like that.
*NOTE - When you first buy a Ethernet cable, the laptop WiFi antenna must be removed, otherwise the laptop will switch between the two, and will make you periodically loose internet connection. Also, the computer will still (not as much) continue to disconnect, and reconnect for a while. Roughly 8-10 days, and then everything should smooth-en out. Here is a link to an image of a WiFi antenna for laptop:
http://www.overclock.net/content/type/61/id/1343839/width/500/height/1000/flags/LL
Or, yours may look something like this:
http://image.dhgate.com/desc_308672220_00.jpg
Hopefully this helps you!
Jan 11, 2013 | Acer America Acer Aspire V3-771-6865 Intel...
My wifi keeps randomly disconnecting.
Usually a bad driver on windows try re-install the driver
Oct 31, 2012 | Sony Computers & Internet
Dell Computer I15N-4092BK problem with wireless adapter
Sounds like you have something interfering with the WIFI and the Laptop, Probably something electronic that runs a lot, find the Item, Move it or unplug it
Sep 16, 2012 | Dell Computer I15N-4092BK Nb...
Hey I have a Acer iconia tab a500 and got an update to 3.2 but now I'm having wi fi issues its always disconnecting randomly and slow to buffer videos
If you are having frequent disconnects then you may wish to try a few changes. Change the broadcast channel for your wifi. Change the type of security if you are using WPA, try WEP. Are you using Microsoft's wireless configuration or Acer's wireless software.
Sep 18, 2011 | Acer Iconia Tab A50010S32u Notebook
I just brought my tv in 3 days ago 55 inch led 240 hz it's just shut off randomly
THE VIZIO XVT553SV has a know problem of random power cycles and random shut offs. It is recommended you call Vizio Technical Support for a proper and permanent solution.
Toll-Free: 877.698.4946 (877 MY VIZIO) Technical Support if you don't get proper assistance at that number call the Executive Office at Phone: 949.428.2525
Jul 18, 2011 | Vizio XVT553SV 55 in. LCD TV
HP Pavilion dv9700 laptop, Wireless stops working at random.
HP's normally use the Atheros wifi card which recently has had many problems such as what you describe here. Try a different wifi card to see if this solves the problem. If you don't have a wifi card take it to a local repair shop to see if they have one they can try for you.
Sep 23, 2009 | HP Computers & Internet
Wifi disconnect on vista business
Try resetting your wireless router frm the reset button on your router....After that goto -control panel-network connections-right click on wireless connection-click on repair
May 02, 2009 | Microsoft Windows Vista Business DVD...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
