Question about Garden
How to tear the gear box on the main beater apart on a 435 h&s manure spreader apart for repair
2 Suggested Answers
emissionwiz
  • 78267 Answers
SOURCE: I have a model 33 John Deere manure spreader that has the beater gear box with worn gears that won't engage. I cannot get replacement gears due to age of unit. Is there a way to repair the gears by we
There is no way to repair a worn gear, this is due to the heat treating of the metal to toughen it against wear and tear of use, otherwise it wouldn't last but a few hours of operation, this precise heat treating of the steel can only be done with special equipment and requires special skills to pull off correctly, so no you will need to get new gears. I know from personnel experience that you can get parts for these old farm implements, call around and see what you can find out. I will say that worn gears are not the common reason for hard gear engagement, that would be worn shift dogs and synchro ring cones or worn gear shaft bearings.
Posted on Dec 13, 2011
JD R-1 spreader controls
www.deere.com
Ask them, they made it.
Aug 18, 2013 | John Deere Model "r" Manure Spreader...
I have an Ortho Whirlybird seed spreader. What setting to use for spreading 3 lb/1000 ft of Prozon Weed Beater?
I too have been going crazy trying to find instructions for this seed spreader. Go to Ortho Products online and select chat. Tell the agent the UPC code for it, which is: 71549-08450. They can then email you the one-page instruction sheet for it. Otherwise try this site where I uploaded it: http://pdfcast.org/pdf/whirlybird-spreader
Jun 22, 2012 | Bonide """bonide"" prozone weed beater"
Dec 13, 2011 | Garden
Beater won't turn, but motor is running.
Hi, Did you push the beater in so that it clicks. If all is good there, gear box maybe at fault or jammed. Take it to a service center for repair. If you are machanicly inclined (DIY) Take it apart and see why its not turning. Good luck.
Jun 04, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
The mixer turns on, motor is running, but the beaters are not turning
Most likely what has happened is that the gears have stripped. The gears inside are plastic but the spindle is metal. When a dough is too heavy and gets caught up in the beaters it tends to eat them. If you take it apart, you will probably find that the gears are shot.
The fix...order new gears, tear down the mixer and replace them. These gears really should have been metal! Check the sunbeam web site for authorized repair places to get your parts.
1. Remove the ejector button...it should pop out with a flat head screw driver. There is a small phillips head screw under it. Take it out.
2. Take out the screws on the bottom. This should allow the face plate on the mixer to slide off, allowing your motor assembly to then be pulled forward.
3. Remove the mounting brackets/shock absorbers...they are rubber u shaped items that hold the motor in. Once that is done, remove the black plastic bracket on the bottom; two phillip head screws. Then unscrew the two long screws underneath. they hold on the speed control electric board as well as the top to the gear box. Pop the silver fasteners on the side of the gear box and you are in. the gears should lift out. put the new ones in and do the whole thing in reverse.
hope this helps.
Nov 29, 2010 | Sunbeam 2350 Heritage Series Mixer
Spreaders how does it work?
An axle or “beater bar” is located inside the bin next to an open slot in the floor. Attached to the axle is a series of beater arms or paddles. When the axle turns, the paddles break up the material and direct it toward the opening where it is deposited evenly on the soil.
Aug 27, 2008 | Earthway 2000a Deluxe Set Up 40 Ib....
Stripped beater gear
It is terminal. This is the fatal design flaw of these mixers. The gears are made of soft plastic and strip easily. Even the gear housing is plastic that is either glued or melted together to make it unserviceable. I have never suceeded in finding the part from either Sunbeam or one of the many appliance repair places on the web (who charge the cost of a new mixer for repair). Sunbeam does not repair them; if it is determined to have malfunctioned due to quality or design while under warranty, it is simply replaced with a new one. I had mine replaced under warranty twice, each time they sent me a new one complete with extra bowls and beaters. Now I have three sets of bowls and beaters and no functioning mixer.
May 25, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Nov 12, 2006 | Sunbeam 2485 MixMaster Series Hand Mixer
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
