Question about Aiwa Audio Players & Recorders
I'm looking for aiwa lx 70 turntable drive belt where can i order for
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Here you go
http://www.lpgear.com/product/AIWLX0070.html
Posted on Jan 04, 2017
SOURCE: aiwa stereo turntable system px-e860k
how long have you had it? could be that you just need a new belt if it keeps slipping off...
Posted on Oct 20, 2008
  • 42 Answers
SOURCE: what size belt do I need?
There are zillions of belts out there. I hope you still have the broken one which will give you the profile of a new belt. Measure the diameter of the sub-platter under the platter. The belt you need well be a slight stretch fit. Then, with the platter back in place, slip the belt over the motor pulley making sure it is not twisted.
Posted on Jan 24, 2009
  • 396 Answers
SOURCE: how do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the motor spindle by using your fingers to turn the round shaft which rotates freely. Remove the rubber mat off the platter. Place the belt around the outside of the drum on the bottom of the platter. From the top of the platter, place your finger in one of the platter holes and tension the belt so it will not fall off or twist. Griping the platter trough the holes while keeping tension on the belt place the platter on the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over the motor spindle. Replace the rubber mat on the platter.
Posted on Jul 21, 2010
  • 256 Answers
SOURCE: the drive belt on my Aiwa px-e860 turntable has
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Posted on Aug 18, 2010
  • 5 Answers
SOURCE: aiwa lx 70 turntable needle arm
This is not a solution but it is information. I just got one of these turntables and the platter rotates but the tonearm does not move. I took it apart after downloading the service manual and found that there are two small thin rubber belts that due to age have fallen apart and "melt" when you try to pick up the pieces. One controlled the sideways movement of the tonearm "carriage", the other controlled the lifting and lowering of the tonearm. The replacements are expensive (I think around $18 each) and in trying to pop loose a worm gear with a pulley buit into it, so that I could try a cheap rubber band out just to see if the unit would work with new bands, I broke the stiff plastic "retainer" that by its shape was designed to be pushed out of the way a bit to allow the worm gear to be removed. The service manual, by the way, had all sorts of information about how to make fine adjustments, but said nothing at all about how to replace the belts. Unless removed there was no way to put the replacement band in place over the gear/pulley combination because there was no exposed end to slip a complete band over. So I think it was a bad design, made worse by the aging of the components that made the bands melt and the plastic "keeper" brittle so that instead of flexing out the way it broke. So I'm going to recycle the components. I did not find any reviews to tell me how good a component unit this was, so before you hire a pro to try to fix this unit you need to figure out if it will be worth it to you in the long run. Anyway, good luck.
Posted on Apr 12, 2011
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
I have Aiwa LX-D10 the arm will not travel or rise or lower, Can you help
Does the platter on the turntable turn? You should be able to make it swing out by hand operation of turning the platter.
If you can do that it's likely that the belt to the turntable is slack and needs replacement.
Nov 12, 2014 | Audio Players & Recorders
Aiwa lx-110 turntable won't spin
chances are that is the drive belt for the platter, check you local radio shack, they used to carry or be able to order those kinds of things
Mar 09, 2013 | Audio Players & Recorders
AIWA LX 70 TURNTABLE THE BELT THAT MOVES THE ARM TO THE RECORD IS BROKEN. WHERE CAN I BUY ANOTHER ONE, AND IS IT EASY TO FIT
Hi jun_tradjazz,
I have an LX 70. There are two drive belts. They are identical and of a standard size, ie., not specific to Aiwa, Quite few years ago these belts wore out on my deck. They became smooth and the pulley wheels began to slip. I was lucky that a local electronics shop in town (Belfast,NI) had spares and replaced them "off the shelf". Sadly they can't do that now.
There are specialist retailers on the net who provide all sorts of drive belts of this type. The trick is to find the spec! Perhaps, if you contact them, they might be able to match a new belt with one of the belts on your machine.
From memory, replacing the belts is fiddly, but not very difficult if you are patient and examine the mechanism carefully.
Although I now use a Rega Planar 3 with motor upgrade and a Rega Exact stylus , I still love the magic of the LX-100 and cannot bear to part with it. A beautiful piece of design with it's link to the Strathean Audio (a Belfast HI-fi company, now defuct) direct drive system that it employs.
Good luck with your search.
Pat Cree
Aug 11, 2011 | Aiwa PX-E860 Turntable
Aiwa lx 70 turntable needle arm
Feb 15, 2010 | Aiwa Audio Players & Recorders
Have Aiwa CX-NA555 with 3-CD turntable. CD's won't play because belt that connects motor to screw-drive on turntable is broken. Where can I get part number and/or replacement belt? Tx.
i have an aiwa cx-na555, the turn table want work the belt is good however when the table slides in it does not raise the turntablr motor into position because the yrllow does not unlock the turntable, its as though it is out of time, ineed help
Dec 07, 2009 | Aiwa Audio Players & Recorders
Looks like the rubber band came off
if it is black and fairly long it's probably the drive belt and it has likely become stretched (or sticky).The belt fits on the inner circumference of the platter- to re-install - remove the rubber platter cover and platter
-stretch the belt around the inner (botom side inner) lip of the platter
- you should see the motor facing up with a brass capstan or drive bobbin
-from the top side of the platter stretch the belt slightly off the platter through the openings provided and while re-installing the platter loop the belt over the motor bobbin.
If the belt flops off the inner platter it's to stretched and a replacement would have to be ordered
Oct 18, 2009 | Aiwa PX-E860 Turntable
What size belt do I need?
Dec 28, 2008 | Aiwa PX-E860 Turntable
131 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
