Question about Refrigerators
Control panel and cooling not working - Refrigerators
    Problem Solver:
  • 19 Answers
Shut the fridge and clean the dust and the lint like stuff accumulated at the Compressor grill like mesh. That stops the air circulation around it.
Posted on Dec 16, 2016
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Mar 31, 2014 | Samsung Refrigerators
When there is a fault with the back to base security system it knocks out the heating/cooling control panel, even though now I have 2 control panels - 1 for heating 1 for cooling.How can the system be
this has appeared under truck and cars try the correct heading to post this question in please and perhaps someone will see it then and not a old washed mechanic like myself
Dec 30, 2011 | Cars & Trucks
My logitech N100 cooling pad has stopped working
first check the connetions at both ends of your cooling pad make sure the connection into your laptop is securely seated and its not faulty
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb pad but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Jun 01, 2011 | Logitech Inc 939-000119 N100 Cooling Pad...
Refrig isnt cooling enough. freezer working good
If the freezer is working like it should, then the cooling system is also working like it should as well. Nothing wrong with control panel or thermistor.
If the fridge compartment doesn't cool down, you may have too much in it hindering air circulation, or perhaps the door gasket is leaking.
Jun 30, 2010 | Dometic NDR 1292 Refrigerator
My unit works great on AC (cools to 30degree), but
Your fridge has two manual settings to adjust it's internal temperature. Obviously, it most likely has a standard control (1-5 or 1-9 depending on the fridge) that you can adjust on the control panel. Some fridges are preset (no control panel adjustment) and must be adjusted on the inside of the unit. If open your fridge, look at your cooling fins. You will notice a metal slider on a wire attached to one of the fins. Moving this sensor up or down along this fin will set the internal temperature of the fridge. You will have to play with it a bit to get it set properly (with a thermometer), but you should be able to get it to the proper temperature. I hope this solves your problem. Thanks... John Charles
Jun 12, 2010 | Dometic RM2652 Refrigerator
Where is the fuse box panel for a 1993 ford tempo
Access the fuse panel from the left of the steering column Relay Center Cooling Fan Controller
  • Located behind the left side of the instrument panel.
Cooling Fan Controller Module
  • Located behind the right side of the instrument panel.
Cooling Fan Relay
  • Located in the air conditioning cooling fan control module.
Electronic Control Assembly
  • Located under the left side of the instrument panel.
Electronic Engine Control Power Relay
  • Located behind the glove box on the right side of the instrument panel.
Fuel Pump Relay
  • Located behind the glove box.
Horn Relay
  • Located in the fuse block.
Oct 13, 2009 | 1993 Ford Tempo
Power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Aug 14, 2009 | Samsung Refrigerators
Mitsubish mr Slim air contioner heat & cooling control panel
HOW TO WORK THE HEATING AND COOLING CONTROL PANEL
- PRESS THE SWITCH ONCE IT OPERATES "COOL"
- PRESS THE SWITCH AGAIN IT OPERATES "HEAT"
- PRESS THE SWITCH ONCE AGAIN IT STOPS.
Mar 05, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
