Question about Nilfisk Vacuums
Nilfisk Meteor vacuum cleaner - how to remove the main wheels?
Need to remove wheels to get at the cord rewind to check the mains lead as it's intermittent power when the power cable is wiggled where it exits the cleaner.
chrispurs1
  • 372 Answers
SOURCE: Dyson Upright Vacuum Cleaner (Poss DC04- its green, if that helps?!?)
Hi.
Check brush roller is spinning & that belt has not snapped.
Check behind brush roller for blockages, Check clear pipe for rips or splits.
Check clear pipe for blockages.
http://dysonmanuals.llc.nu/
Chris.
Posted on Jan 16, 2008
  • 10 Answers
SOURCE: cord rewind nonoperational
sounds like the spring is either over stretched or broken. you may have to have the spring replaced
Posted on May 11, 2009
  • 250 Answers
SOURCE: taking apart dc05 dyson vacuum cleaner
You have to take the wheels off first to get at two securing screws on each side of the cleaner. First of all remove the plugs in the centre of each wheel (you will probably damage them prizing them out but they are available online as replacements if you make to much of a mess - look online anyway to see what you are dealing with).
Posted on Jul 04, 2009
  • 430 Answers
SOURCE: Nilfisk Family Vacuum - Strong Awful Odor
Not sure what a bacteria smell is perhaps you mean a mildew type smell.
If you have picked up something wet, start at the front of the vac and work your way to the exhaust.Change the front most filter first. Baking soda may help to eliminate some of the odor.
Personally as an allergy suffer, which you may be given the Brand I would remove all and let them and the tank air outside. Meanwhile install a fresh set.
Posted on Sep 13, 2009
SD Tech
  • 14553 Answers
SOURCE: How do I open a Nilfisk Action Plus vacuum cleaner?
l have a question but no answer for your question--is switch actually broken or unit will not power on?
Posted on Dec 17, 2012
How do I put a new wheel on nilfisk a300
by the picture of the
nilfisk a300 replacement wheels
its a pull off clip on type design
the axle should be metal
it will need some force to remove the old wheel
may even try to break the old wheel off in pieces
Sep 07, 2016 | Nilfisk Vacuums
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
Change front wheel on x300
The front wheel on a Nilfisk Extreme 300 is changed by removing the 3 screws inside the bag chamber. From memory they are a torx screw driver size 15 or 20. Basically remove the bag and take out the 3 screws in the middle of the chamber - the wheel will fall off once you lift the machine up. If you need to buy a replacement wheel you can find one here.
Nov 10, 2013 | Nilfisk 11730410 Micro Filter Polyester,...
Cable will not retract
If you are having problems with a NIlfisk King cord reel it will either be that the cord is simply dislodged or the retract could be faulty. I have made a video showing how to pull it apart which could be used as a reference to diagnose the issue.
If you need a new retract we have these available online as well, the part number is 22352606 Nilfisk King Cord Rewind
Feb 18, 2012 | Nilfisk Vacuums
Sep 13, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
My Nilfisk vacuum cleaner overheating and stopping
Its probably clogged..
Remove the hose,, straghten it out so you can look into it..
Could be clogged where the hose connects inside the unit..
Jul 26, 2009 | Vacuums
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Power cord won't retract on anaerus 5500 vacuum cleaner
What you can do is take out the six hex screws on the bottom of the machine while on it's back. When all the screws are out, flip the machine back over, making sure you don't lose any of the screws. From there, open the bag cover and leave it open. Remove the cord release button. (The big rectangular button near the rear of the machine. Usually a firm pull up will get that thing out without incident.) Grasp the handle with one hand and hold the machine steady with the other. With a firm pull, pull upwards. This should seperate the chassis from the main cover.
With the machine guts exposed, place the main cover on the side for now. Now, this next part you can do one of two ways. You can either leave the cordwinder wires attached, (there's only 2 connected wires to the cordwinder, the white and black. Black is on the inside prong while the white is on the outside) or you can take the wires off. I find it easier to disconnect the wires.
Now, remove the cordwinder from it's place, making sure you take note of how the cordwinder rests in the groove from the motor. From there you can rewind your cord fully. Once this is complete, continue winding the cord while holding the cord in place. Take note of the spring. Make sure you are winding in the direction that is TIGHTENING the spring. Make sure you don't overtighten as the center plastic piece will surely snap due to the overtension. This may take a few tries, but be patient. Once you have met your estimated tension needed, replace the cordwinder, put the cover back on WITHOUT SCREWING IT BACK IN PLACE and replace the cord rewind button.
Replace the large cord release button and pull your cord out at least halfway. Hit your Cord rewind button. If your cord rewinds fully, congratulations, you got it in one try. Replace the screws and you are finished. If not, re-open the machine and continue rewinding the cord in the direction that TIGHTENS the spring with emphasis on overtightening. Once you break that center plastic prong, you need to buy a new cordwinder, so emphasize patience. If you're getting frustrated, go take a break and come back. Repeat until the cord winds fully, replace all the screws and you are finished.
Apr 20, 2008 | Electrolux Vacuums
Hoover Model S3281, disassembly instructions
GET TO THE REEL AS FOLLOWS:
(BEFORE YOU START, BE SURE TO UNPLUG THE DIMENSION FROM THE OUTLET)
1). TURN VACUUM OVER AND USE A FLAT-BLADE SCREWDRIVER TO WEDGE/SLIDE THE WHEELS OFF (PUT THE SCREWDRIVER BLADE BETWEEN THE LITTLE BLACK WHEEL BRACKET PIECE AND THE GREY CHASSIS OF THE VACUUM AND SLIDE/WIGGLE THE WHEELS OFF);
2). THE 2 DEEP HOLES AT THE TOP OF EACH WHEEL RECESS LEAD TO 1-1/2" LONG PHILLIPS SCREWS >> UNSCREW THEM;
3). AFTER REMOVING ALL 4 SCREWS, YOU SHOULD BE ABLE TO EASILY LIFT OFF THE TOP OF THE REEL/MOTOR COMPARTMENT.
4). CAREFULLY LIFT AND ROTATE THE CONTROL PANEL TO THE SIDE.
5). THE REEL IS NOW IN PLAIN SIGHT.
6). I’M STILL TRYING TO FIGURE-OUT HOW TO SAFELY ACCESS THE GUTS OF THE REEL MYSELF. I HAVE A PROBLEM WITH INTERMITTENT VACUUM POWER AND ALSO WITH WEAK CORD RETRACTION.
ANYWAY, GOOD LUCK TO YOU !!!
Jan 01, 2008 | Vacuums
Vacuums Logo
Top Nilfisk Vacuums Experts
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
