Question about Cell Phones
Where can I get a optical for my Emerson ms 9700
I think my optical is bad on my Emerson 6cd changer ms9700 cause think it's not reading my cds
If you can get access to the lens, you might see if it is scratched or damaged. If it is not it could be just dust.
Dec 16, 2016 | Emerson Audio Players & Recorders
What causes brother mfc-9840cdw scanner streaks?
optics, open up and just clean every thing you can get at, a streak, will be dust in optics, clean mirrors etc, if very fine lines on every thing, as you say laser printer, would be drum damage. just on scans dust. might need to take top glass plate off.
Jul 29, 2014 | Brother MFC 9700 All-In-One Laser Printer
Emerson tv DVD says disk error
clean the disk and use a lens cleaning disk for the lens. if it spind but won't read, you need to replace the optical pickup. if you don't hear the disk spin, you have a bad motor and still need to replace the optical pickup.
Feb 13, 2011 | Emerson Televison & Video
Emerson 3 Compact Disc Player - TOC Read problem - wont play CD
Hi
If the machine cant read the table of contents of a disc this would suggest either the lens of the optical pick up is dirty or the optical pick up has failed completely or something directly relating to the optical pick up i.e the spindle or stepper motor, if you can easily acess the optical lens you maybe able to clean it using a cotton bud and re-test, just try this with a dry contton bud to begin with if this gives an improvement you may wish to use a cotton bud with a alchol cleaner like I.P.A,
make light circular movements over the lens. If this makes no difference the machine requires repairing, so consult a local service engineer.
regards
TechSupp12
Dec 11, 2010 | Emerson MS3100 3-Disc CD Changer
Everything works on my emerson MS9700 except the cd player. the display keeps saying no rdy. how can i fix this?
If the indication says" not ready " it means that the disc is not reading the data present on it . It is possible that the disc is not scanned by the optical head to be ready to play.
So it is possible that the optical head is defective or weak, please try to clean the optical eye with ear bud very softly or use a disc cleaner.
If there is no result the head can be faulty.
If the set was not used for long time please keep it powered ON.
Also the processing section/main board can be a suspect.
Nov 19, 2010 | Emerson EM-MS9700 6 CD-Changer stereo...
Scrren froze up while watching a DVD
clean the DVD player with a cleaning kit you buy from any eletronics store. If that does not work you need to service this as the optical laser is not functioning when it heats up at the solder joint this would cause artifacts and freezing as you prescribed. So diagnosis dirty optical laser or malfuctioning optical laser at solderjiont.
Sep 23, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Can I use a new MS wireless mouse to replace my existing MS wireless mouse. Currently my mouse and keyboard connect together on the same wireless USB device. Could the new mouse be detected and be used...
I suppose there is a reset button on the keyboard or the software provided so I suppose it could be possible, I don't know.
I use a Microsoft Wired Keyboard...
But Best of luck.
Jul 21, 2009 | Microsoft Wireless Optical Desktop Pro +...
MS Optical Mouse 4000 problem; computer mouse pad no longer functional
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Aug 08, 2008 | Microsoft Wireless Optical Notebook Mouse...
Troubleshooting MS wireless optical desktop for bluetooth
your keyboard may be hogging your computer and not letting your other things work i would check your keyboard's properties
Feb 26, 2007 | Microsoft MultiMedia Keyboard
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
