Question about RCA 20F510TD 20 in. TV/DVD Combo
20F510TD This TV/DVD combo will play audio CDs, but when I insert a movie DVD, it "loads" for a while, and then always reports "no disc."  I do not have the original remote, but I don't think this should matter since I can get the audio CDs to play manually.  Thanks for your help.
  • 111 Answers
Re: 20F510TD
Eject the cd tray and use canned air to clean the inside of the cd/dvd unit, just use stick the nozzle near the opening and give it a through dusting. after that, run a cleaning disc through it a few times.
if that doesn't clear up the problem, the dvd player will need to be serviced, most likely either a lens replacement or re-alignment.
hope this helps,
Posted on Nov 20, 2007
0 characters
3 Points
I have been playing DVDs without problem for several years on my RCA 20F510TD 20 in. TV/DVD Combo. Now when in the DVD mode, with a disk inserted, the screen comes up with no disk found. What can I do
NOT much you can do---It is a bad optical unit inside the DVD unit---they do not see parts----only the complete DVD portion----much cheaper to go out and buy a DVD player and connect it to the audio and video jacks this unit should have.
Mar 22, 2012 | RCA 20F510TD 20 in. TV/DVD Combo
Suddenly my MW24F11 cannot read the disc and says to insert disc
On some of the movies I bought from the store I am trying to play them on my Panasonic DVD and I get the message "This type of disc cannot be played" WHY??Doesn't say that with all movies.
Jun 21, 2009 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
DVD locks
right does it say parental control and then you have to put the code
Jan 27, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Wrong Disc
You now have a optical block problem. An alignment may do the trick, but you'll be out the estimate if it's a major repair and you refuse to dump more cash into it...accordianman
Dec 29, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Dvd troble
some dvd players dont play all dvd. i think the dvd player dont support the format of your dvd movie try a different dvd movie.This msg show up in every dvd you try to play????
Dec 14, 2007 | RCA D52W135D 52 in. TV/DVD Combo
DVD player
Clean the pickup using a commercial cleaner disc.That's the only quick,cheap fix.
Dec 12, 2007 | Toshiba MW20FM1 20 in. Combo
20F510TD RCA
20f510td rca cant get past the pass word input....
Oct 13, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
RCA 20F510TD 20 in. TV/DVD Combo Logo
117 people viewed this question
Top RCA Combination Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Combination Television Expert? Answer questions, earn points and help others
