On display hh on display and alarm - Audio Players & Recorders
Code HH on display unit wont charge laptop
I cannot find a code HH. What make and model of laptop have you?
Nov 03, 2013 | Computers & Internet
Display panel shows 6522 Rev HH
check wiring to controller either wires touching at plugs or wires cut
Sep 11, 2012 | Jandy Aqualink Rs4 One Touch Control...
What does hh.h mean on display
I'm assuming it just stands for "High Humidity". It wasn't raining at the time, but it sure had been earlier, so perhaps if it's over some number (like 90%), it just says "HH".
Nov 01, 2010 | Acu-Rite AcuRite 00592A2 Wireless Humidity...
How to change the time format from 24 hour to 12 hour in windows 7 thank u.
  • click on Start > Control Panel, and choose Regional and Language Options.
  • Click the Customize button underneath the Standards and formats section.
  • Click on the Time tab and change the time format to H:mm:ss (note the uppercase H) and press OK
  • Below that button, you’ll also see an example of how each setting is currently configured for Number, Currency, Time, Short Date, and Long Date.
  • Type uppercase H or HH to Display time in a 24-hour format
  • Type lowercase h or hh to Display time in a 12-hour format
  • Type two characters, HH or hh to Display leading zeros in single-digit hours
  • Type a single uppercase H, or lowercase letter, such as h, m, or s to suppress the display of leading zeros in single-digit hours, minutes, or seconds
  • Type lowercase t to display a single letter to indicate AM or PM
  • Type lowercase tt to display two letters to indicate AM or PM
  • Type single quotation marks (’) around text to display text
  • Aug 10, 2010 | HP Computers & Internet
    My alarm won't ring or vibrate, but both work when someone calls me. I have it set for vibrate/ring but the screen just lights up when the alarm goes off, doesnt vibrate or ring
    Reboot the HH,restart the HH and follow the follwing steps Press Menu,Select Clock-press menu-select alert type as tone-select the tone from the given list and save it.Check whether if you are able to listen to the tone.
    Aug 04, 2009 | RIM BlackBerry Pearl 8100
    How do i change the time on my samsung prostar 816 phone?
    1. Enable technician programming mode
      • Press "#" - "PROGRAMMING" is displayed
      • Dial "20" - "MMC ENABLED" or "MMC DISABLED" is displayed
      • Dial the password (default - 1234) - if wrong password is enter "ERROR" is displayed
      • Dial "1" to enter program mode
      • Press "#"
    2. Press "#" key - "PROGRAMMING" is displayed
    3. Dial "55" - the display shows "YY MM DD W HH MM" and then the current date is displayed
    4. Enter the new date
      • YY = Last two digits of the year
      • MM = Month (01 - 12)
      • DD = Day of the month (01 - 31)
      • W = Day of the week (1 -7 day of the week begins on Monday & ends on Sunday)
      • HH = Hour (Use 24 hour clock)
      • MM = Minutes (0-59)
    5. Press "#" - new date is saved
    Jul 24, 2009 | Samsung Prostar 816 Phone
    Display problems
    From the attendent's phone, press # 06, enter password ( 4321), enter 1, enter #. You are now in programming mode, enter # 55, enter YY MM DD W HH MM where W= Day of week ( 1=Monday ) and HH MM must be in 24 hour clock format ( 1:00 PM = 1300 ),enter # to save. Good Luck.
    Jul 21, 2008 | Samsung Prostar 816 Phone
    PROSTAR 816 PLUS
    First to change the clock to a 12 hour instead of a 24 hour requires a bit of CAUTION. You have to go into the technician level of programming so be careful. From a display phone, Press #, ( Programming ) is displayed, enter 20, ( MMC Disabled ) is displayed, enter password ( 1 2 3 4 is default ), enter function 4 for 12 hour clock, enter # to exit. If the time and date are displayed wrong you have to go to # 55 and reset time and date.
    YY MM DD W HH MM format. W = Day of week with 1=Monday and HH MM must be entered in Military time even though you have a 12 hour clock set. Good Luck
    Jul 02, 2008 | Samsung Prostar 816 Phone
    Motorola M385 External Display
    go into time setting and change from 12 hour 2 24 hour. reply me
    Jun 02, 2008 | Cell Phones
    Setting date/time display
    First, you have to Enable Customer Programming. - With handset on-hook, dial #06. The display shows [MMC DISABLED]. - Dial the passcode and '1' and then dial #. (If you don't know the password try 1234, 4321, 9999, etc.) At this point, customer programming is open... Next, Setting the date and time. - Dial #55. Display shows [YY MM DD W HH MM]. - Dial new information as follows: YY = Last two digits of the year MM = Month (01-12) DD = Day of the month (01-31) W = Day of the week (1-7; week begins on Monday (1) and ends on Sunday (7)) HH = Hour (use 24 hour clock) MM = Minutes (00-59) - Dial # to set current date and time. The phone returns to normal use.
    Oct 30, 2006 | Samsung Prostar 816 Phone
     Grubhead
    Grubhead
