Pair Ls 15. thought 1woofer was bad cuz it would play at lower levels but turned up it would rattle. Put it in other one-time no prob!Do I need to replace the crossover?also is a lw15 a 8Ohm woofer?
early1234
  • 871 Answers
SOURCE: LS-15 Woofer
realize that we dont live in one place only. prices there might differ from here. but the price of a replacement shouldt be that expensive.
Posted on Jan 14, 2008
  • 4234 Answers
SOURCE: Lost woofer in one cabinet.
I'm not familiar with your specific model, but some of these have fuses for the woofers. Check for a blown safety fuse. Also, verify that the connections to the crossover board are in good shape. These crossovers are not that complex and don't usually fail. Keep us posted on what you find.
Dan
Posted on May 29, 2008
SOURCE: speakers and OHM's
it will work temp. but it may put to much of a load on the receiver
Posted on Jul 27, 2008
oilcitycompu
  • 3 Answers
SOURCE: i have a set of cerwin vega ls-12 3way woofer works but tweeters
There is an old cheap way to test any speaker. If you have a multi-meter, set it on OHMS. Then, while holding one lead against one speaker terminal, tap the other meter lead to the other speaker terminal. If the speaker is good, you will hear faint crackles. If you do not have a meter do not despair, you can do the same test using an AA or AAA battery with leads held to the battery.
Good luck! P.S. Nice speakers.
Posted on May 22, 2009
  • 18 Answers
SOURCE: THE WOOFER RATTLES REALLY BAD WHEN ANY MUSIC OR
you can have the woofer reconed, refoamed or replaced. if the voice coil is bad then you can only refoam or replace. if the problem is that the poly foam surround has dry rotted, then it can be refoamed or you can purchase a DIY refoam kit. there are also many replacement woofer options.
cathy@speakerex.com.
Posted on Jun 25, 2009
I have a 1997 pontiac grand prix gtp supercharged coupe my power steering hose popped off and i put it back on do i need a new one or is the pump gone i need help cuz its hard to turn
if you put the hose back on and put new fluid in it and it it is still hard to turn which means you pump prob went bad , make sure you have enough fluid in it first, you could have blown you rack and pinion but not likely
Oct 21, 2014 | 1997 Pontiac Grand Prix
I have a pair of Cerwin Vega LS 15-series home speakers. One of the subs stopped working but still has sound coming out of the voice coil. Do i need to replace the sub?
You need to check the connections on the cross over board and also Ohm out the speaker to see if the voice coil is open. If you cannot get the same woofer, then you should replace them in pair, try http://www.parts-express.com//index.cfm?
Feb 25, 2011 | Cerwin Vega LS-15 Speaker
My LS 400 is parked. I was at a drive thru and it started idling low, then wouldn't excellerate. This happened about a week ago. I put about 2 quarts of transmission fluid in it. The problem went away,...
my ls 400 just started doing the same thing, stays in a low gear, i havent got the answer yet, having it checked out, im thinking its the speed sensors, it has 2, but it did this before and it was a bad spark plug wire, when i find out i will let you know, im working on it now,
Sep 01, 2010 | 1991 Lexus LS 400
All of the front brake harware does not fit
Send me $9.99 & I will tell you how i did it.
Jun 13, 2009 | 2000 Lincoln LS
Top loose, new dryer not level? rattle when start
No dryers are not self leveled. You may not have put the legs on ? they come in the box or if you have then you need to prop them up with a 1x4 or something.
Apr 19, 2009 | Kenmore 500 6952 Dryer
1992 LS 400 Lexus. Car wouldn't start. New battery, thought was fuse problem, but no, towed in and mechanic says need new starter but starter under the engine block, will need new gasket for block after...
remove black plastic relay cover in plastic underhood fuse box and activate relay9006980.jpg with a very small screwdriver and ignition on. If starts, obviously the starter is fine, if not the starter is indeed bad and needs replacement so hold onto your ankles cuz it's gonna hurt.
Mar 01, 2009 | 1992 Lexus Ls 400
Whining sound from front passenger side.
Check the condition of front disc brake pads, if they are in need of replacement a preset little metal arm starts rubbing the discs and will make a whining noise. It doesn't do any damage but it's irritating to listen to.
Nov 25, 2008 | 2000 Saturn Ls 4dr Sedan
Freeze'n
yo dude i have the same problem as u like im playing cod4 wen i exit a match it freezes wen i play guitar hero 2 that also freezes while playing a song i think i know sum ways. its either were playin to much u need to buy 1 of those disks that clean inside the ps3 or any dvds its like a special disk it just goes inside and u play it and it takes like 5 min cuz none of my games have scratches
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Lexus Cd-Changer
lol had this prob so many times, you will find that you have moisture in the cd exchanger and the way i found this out was on removing my cds first thing in the morning a noticed very slight misting on most of the cds. .i put the wifes hair dryer and blasted warm air into it for a good 15 minutes waited till it cooled down cleaaned carefully my cds replaced and away i went. hasten to add that this was temporary a few days later i got the odd cd not playing . i notice the prob more in cold weather and if the car has not been used for a few days. the boot maybe damp .. good luck .stu
Aug 19, 2008 | 1996 Lexus LS 400
46 people viewed this question
 Grubhead
Grubhead
