J
Jerry Idziak Posted on Dec 16, 2016
Jvc sp hxd 77 paired with other amps?
I was wondering if I can match speakers from ivc hxd 77 (twin giga with built in subwoofer) to an integrated amplifier or stereo receiver. And if yes, would it work?
5 Related Answers
Anonymous
  • Posted on Dec 18, 2007
SOURCE: Bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Anonymous
  • 1512 Answers
  • Posted on Mar 22, 2008
SOURCE: JVC AX-33 Stereo Integrated Amplifier - very little sound!
Hi xaser
Check that someone has not turned on the tape monitor or mute. Both of these may cause the problem. Is there alot of noise with the sound you are getting when you turn it up?
regards
Graeme
Anonymous
  • 16 Answers
  • Posted on Apr 16, 2008
SOURCE: JVC Subwoofer problem.
You may have a break in the wire. You can find out by slowing moving your fingers down the wire until you notice sound coming from the subwoofer. You can fix it yourself by cutting about an inch away from the break both ways. Then cuttings some of the wire off, so the copperwire is exposed. then wrap the two copperwire ends together and seal it with elections tape. or Try replacing the 60 watt subwoofer wire.
Anonymous
  • 7 Answers
  • Posted on Jul 13, 2008
SOURCE: Subwoofer Line In/Out Mix-up
I had a problem with no audio and I recently found the fix. When the sub still worked and you turn it on you hear one relay click and then about 5 seconds later a second relay clicks and the audio comes on. The problem I had lies with that second relay. When you take the case apart there are 4 circuit boards. The big board with the two big blue capacitors is the main board. Well next to the two blue capacitors is a blue relay. That relay had a pin that came un-soldered from the circuit board. I re-soldered that pin and the sub works just like new. If you go here http://www.eserviceinfo.com/downloadsm/20627/sony_sawm500.html you can find a free service manual that has the wiring schematics for the amp. Hope this helps!
Anonymous
  • Posted on Jan 07, 2009
SOURCE: connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Ad
    What model sub woofer can replace JVC SP-PW100?
    open corel, at top click on about- click on activate and enter code
    I have no amplifier
    if there is a built in amplifier inside your subwoofer you can use it.
    I have a jvc sp-pw50 Subwoofer and i want to know if you can buy an adapter for the input so i can hook it up to my kenwood amp? my amp does have a regular audio jack
    That would require you to disassemble the subwoofer cabinet and disconnect the the supplied amplifier.
    Connecting this unit to a different amplifier would provide no benefit to you unless the on-board amplifier became damaged.
    The cone is busted15"
    It might be cheaper and easier to snag a whole speaker or even a pair on eBay or craigslist than to locate and obtain the exact driver.
    examples:
    http://cgi.ebay.com/JVC-SP-7700-Main-Stereo-Speaker-/270738470371?pt=Speakers_Subwoofers&hash=item3f094535e3
    http://joplin.craigslist.org/ele/2263290479.html
    1helpful
    My jvc subwoofer inner speaker windings blow up and i m either willing to purchase the whole sub set or jst the inner speaker.the model number is sp-pw 105wd.theserial # 119k0101.
    I would suggest to buy the entire cone speaker because the inner windings is harder to find or not available.
    The cone speaker part number is: CR160058-01. Try contacting this website to find the cone speaker or you could find a cheaper speaker cone with the same dimensions and wattage.
    I can also send you the service manual for this subwoofer.
    JVC sp-pwm606
    Hello, it,s very possible that it,s circuit protector built in to the sub (if it,s a self powered sub) gets to the point of overload and shuts off as a protection so that the speaker won,t get damaged and also so the internal amp tha,t pushing the speaker sound is also protected since theese amps all have heat buildup, their are two types of subwoofers ,They are the powered ones and the ones that are powered bt the surround amp ,The ones powered by the stereo surround amp/tuner tend to throw out less power to the sub and the ones that have internal power are mostly higher powered , Another thing you might want to check is your polarity to the speakers and also the omage , Most home theater system speakers are 8 ohm,s but their are speakers and amps that can be changed to 6 ohm,s ..so you might want to check the speaker rating also . Well hopefully you can use theese different methods to at least troubleshoot and discount the thing,s that are not the issues , Good luck and hope theese sugestions might help you , Sincerely Glenn
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
