Question about Dryers
My kelvinator ktd600md drum is not turning, I used it 4 times. My maid washed clothes in the bath and put it directly into the tumble dryer and it hasn't worked since. Any idea what it could be?
    Top Expert:
  • Dryers Master
  • 41,738 Answers
The dryer electrical parts probably got drowned by the sopping wet clothes.
Posted on Dec 16, 2016
Testimonial: "HI Tom, everything still works, lcd display, function selection, capacitor on the motor is fine, motor is fine.drum just doesn't want to turn"
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
WHAT DOES "E5" error code means? I've got a KELVINATOR KTD600MD T/DRYER
water not been filled quick enough have you made sure the water is turn on fully and check the filter they get clogged up
Sep 12, 2013 | Smeg WDI12 Front Load Washer / Dryer
HOW TO FIT A DRUM BELT ON A TUMBLE DRYER KELVINATOR
Normally you loosen the bolts to the motor after fitting the belt around the drum. DON'T try to streach the belt to fit over the motor pullery.
Dec 19, 2011 | Dryers
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
GE hydrowave 5550 will not spin!!!
go to a laundromat as this is not a quick fix.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Jun 18, 2009 | Washing Machines
Dryer sped too fast?
Put a couple of clean dry bath towels in with your knit shirts.......problem solved
May 29, 2009 | Whirlpool LEB6300 Electric Dryer
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Dryers Logo
Top Dryers Experts
