How do I get the subwoofer to operate with a Apex sound bar?
The sound bar suddenly stopped pairing with the subwoofer. The only sound is coming from the bar
I suggest turning off and unplugging everything from the power, then disconnect everything from each other. See if you can get it to pair again. Otherwise, please give more details on which model sound bar and subwoofer.
Thank you.
Feb 28, 2016 | Audio Players & Recorders
Bluetooth connection
I've never seen a TV with built in Bluetooth. Some sound bars can connect to your phone with Bluetooth and others use Bluetooth to enable the accompanying subwoofer to operate wirelessly so you can place it anywhere. Most sound bars connect with an optical cable to audio out or digital out on the back of the TV.
Nov 27, 2015 | Samsung Televison & Video
Can't sync my JBL SB400 subwoofer to the soundbar?? flashes blue and goes back to orange. Sound bar works but can't pair sub!..HELP!!
After turning the soundbar and subwoofer on for the first time, you will need to "pair" the subwoofer and soundbar so they both operate at the same wireless frequency. To pair the units, press the Wireless Pairing switches on both units within 30 seconds of each other. The units will communicate with each other and operate at the same frequency.
May 21, 2015 | JBL Audio Players & Recorders
Adding more sound
According to, it has a headphone output so it can work with a sound bar that has headphone to RCA inputs
Dec 06, 2013 | Apex Digital Apex 32 in. LED 720p 60Hz...
Pairing my lsb316 sound bar and subwoofer
There is a button on the back of the sub that you need to press to complete the pairing..the led will be green when paired successfully or red if it is in standby mode
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
How to hook up a sound bar to a Apex 32in tv # Ld 3288 t
Please follow guidelines in operation manuals of both.
Jul 25, 2012 | Televison & Video
I have a 8 years old apex tv. while watching tv the picture went out but it still has sound. i can't see the channel numbers or volue bar is it worth fixing
I WOULD SAY NO ! THE PICTURE TUBE IS PROBABLY AS MUCH AS THE TV IS WORTH. i had a very nice sony trinatron tv. the picture tube whent on it at about 5 years so I CALLED FOR REPAIR AND THE PICTURE TUBE WAS 2-300 DOLLARS. good-day !
Jan 20, 2012 | Apex Digital Televison & Video
My 210 visio sound bar keeps losing volume then come back on then goes back off
You will need to take the following steps to ensure that the Vizio wireless subwoofer is working properly:1) You will want to make sure that the subwoofer is in the line of sight of the Vizio sound bar.
2) Ensure the Vizio wireless subwoofer is not beyond 60 ft. away from the sound bar.3) Unplug both the Vizio sound bar and the Vizio wireless subwoofer for 30 seconds and then plug back in.4) Try re-pairing the devices. Pairing works best when you have the devices facing each other about a foot apart during initial pairing, once they are paired you can move them to your desired location.
Sep 12, 2011 | Televison & Video
Can't see bar at bottom of screen - apex at2402
Try changing your screen size,you may have it zoomed in but its something to check.
Feb 14, 2010 | Apex Digital AT2402 24" TV
44 people viewed this question
