Question about Vizio Televison & Video
I have a 32 inch vizio tv, when I look in the back of the tv there is backlights so I done the flashlight test,when I pushed the menu button I couldn't see the menu. Can you tell me what's wrong
SOURCE: I lose Audio from internal speakers Vizio
This issue is actually caused by my cable box. Access the audio SETTINGS on Hand held Cable Remote, and turn on the HDMI and or "Digital Audio Out" option. found on 'more' settings list. This should fix the issue. I had assumed the Cable companeis 'Boot' would have installed this feature during its initialization.
Posted on Dec 20, 2009
TV #1
  • 129 Answers
SOURCE: my 32" lcd vizio vx32L turns on there's sound
Have you tried the T-con board?
Thank you,
Posted on Dec 18, 2010
SOURCE: My Vizio TV tells me,
Funny, same thing happened to me about the same time! Took me a while to figure out how to fix it. You have to get to the HDTV Settings menu and hit the Help icon. Do a Clear Memory/(Factory Default) and go thru that process, basically you go through all the settings just as you did the first time you powered up the TV. This will fix your problem.
The challnge is...how to get to the HDTV Settings menu when your VIA button only brings up the error you described? I finally got there like this: Hit the "Input" button on the remote, navigate to "TV" and hit OK (basically just select TV as your input), hit the Menu button on the remote and that will bring up the HDTV Settings menu and then proceed as above
Posted on Mar 26, 2011
caroldon
  • 17129 Answers
SOURCE: Flat Screen 42 inch Vizio
You can use your phone camera to test the remote. Place the remote to the camera and push to see the IR on the camera. If this works for more than 3 minutes then the IR detector or the processor circuit in the main board is faulty.
This means you need to remove the main panel and use a multimeter to test when the remote is used, trace and see if the fault leads further to the processor.
Posted on Jul 18, 2011
Testimonial: "I will try this procedure,,wish me Luck!!"
Slinteriors
  • 8617 Answers
SOURCE: Vizio Model SV320SVT powers on, after Vizio splash screen it goes blank. Power stays on, but no backlight on screen.
Yes its very repairable as long as the logo stays white you can assume the main boards good. I would recomend contacting the people at www.tvrepairworld.com by hitting the contact us button from their website. They will be able to assist you in finding out whats happening with the set for free. They have most parts available as well.
Posted on Aug 07, 2012
What component or components need to be replaced to fix the tv?
Try replacing the inverter board which powers the backlights on set.
Mar 18, 2016 | VIZIO P702ui B3 70 Inch Ultra Smart
LED TV - replaced power board but still no backlight? LED backlights do not seem to work.
yes the led backlight for whatever reason is not functioning and that is the root cause of your problem. Unfortunately to find a replacement led backlight is tough as the backlight is normally fixed with the lcd panel and has to match the voltage and all that stuff with motherboard. and if that doesn't match you might short the tv itself. this case is as good as getting a replacement lcd panel.
Feb 17, 2016 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers ยท Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
Aug 07, 2012 | Vizio SV320XVT 32 in. TV
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Televison & Video Logo
20 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
