Question about Pioneer Car Audio & Video
Can you help me know how to connect a car radio carrozeria pioneer avic drv02(cpn2162)to a battery.
Want to know the colour codes of power and speakers want to use it at home
tech48
  • 624 Answers
SOURCE: Pioneer 760W (Mosfet Power Supply) Amplier
If you are connecting the negative lead of the voltmeter to the chassis of the car, and then checking the voltage at the amp on the ground power input of the amplifier, then your amplifier is not grounded properly. The amp should also be grounded on the chassis of the car, so if you have 4 V DC on it, it can not possibly be grounded to the chassis. The chassis is the same potential at any point on the car.
Could it be that the 4 V DC is at the power terminals +B or positive voltage? That would not be an uncommon thing to have since the amplifier will hold some charge after it is turned off and that would be normal.
Since you have a voltage meter, you could check the current draw of the amplifier if your meter also have a setting for current or amps.
If so, connect the meter in series with the ground of the amplifier. That means to disconnect the ground wire at the amplifier, and use the meter to complete the ground connection by putting one lead of the meter on the ground wire that should be connected to the chassis of the car and the other lead to the ground terminal of the amplifier. It does not matter which lead you connect to the wire or the amplifier, that would only make your measurement i postive current or negative current, but the meter must be set up properly for current. Most of them have a diiferent jack to put the positive lead into for current. most have two different jacks. If yours does also, choose the lead with the larger amp rating. Most have 10A and 300mA, the lareger amp rating is 10A. That is 10 amps max and the 300mA means 300 milli-amps which is .3 amps max.
Do this with the amplifier turned off and the car off. If you measure any current at that point you do have a current draw with the amp off and the amp would need to be serviced by a professional. If you have no current draw there, the amp is not the source of your battery draining. This would find out for certain if the amplifier is really draining the battery.
If you have found this information help a rating of "FixYa" would be appreciated.
If you need more help just ask,
Dave
Posted on Jun 27, 2008
SOURCE: Car Radio
I just bought a 3.5 mm aux cord for my ipod but when i press the SRC button, the AUX option does not appear. What am i doing wrong setting this up?
Posted on Jul 14, 2008
GooFyTiS24
  • 33 Answers
SOURCE: Need to know the speaker
what code you talking bout, like which color goes to what... i need more info...
Posted on Aug 12, 2008
lobsterman72
  • 91 Answers
SOURCE: PIONEER DEH 245
Most aftermarket radios follow the same color code. W G G P, White, Grey, Green, Purple. LF, RF, LR, RR. red is switched ignition, yellow is constant battery, black ground.
Posted on Sep 02, 2008
  • 92 Answers
SOURCE: Hi - I have taken
When dealing with vehicle wiring, assume NOTHING! Your best bet is to go to a place that sells adapter plugs (wal-mart will probably even have them) and save yourself the hassle of trying to figure out the factory wiring. It will plug directly into the vehicle wiring harness and will have wire colors that should match exactly with most aftermarket car stereos saving you the guesswork. As an installer for over 15 years I have seen many attempts at wiring to a factory system without an adaptor plug and the results range from the system not working to doing major electronic damage to the stereo and even the vehicle.
In addition to it being a headache to try and figure out, many newer vehicles use some of those wires as data carrying lines and there are things in the factory stereo which control other things in the car ie: door chimes, air bags and others.
If you are hell bent on doing it the way you have started, please provide vehicle information and I can advise you further although I do not recommend doing it that way.
Posted on Oct 08, 2008
Changed battery in the car. Now Pioneer AVIC-D3 will not power on. Can you help. Fuse seems to be fine
by pulling the battery you have activated the theft code
reinstall the code into the radio and it will work again
Jan 20, 2016 | Pioneer AVIC-D3 Car DVD Player
Pioneer avic drv150 setup file free download
i have pioneer carrozeria avic-drv150 whin i run mp3 file more then 3MB its says file content error.plz help me
Mar 03, 2013 | Philips Car Adapter For Ay4197 Dual Screen...
PIONEER RADIO NEED CODE
The code that came with it to activate it. It should be on a small card
Nov 25, 2012 | Pioneer Repair Fix Service For Avic-x920bt...
How can i change the language for my pioneer carrozzeria from japanese to english
how can i change the language for my pioneer carrozzeria from japanese to english
Nov 29, 2010 | Pioneer AVIC-D2 DVD Nav/6.5"...
Change language change from japanese to english on pioneer carrozeria HDD AVIC-HRZ88.( only display japanese on screen)
CHINESE MAKERS SHOULD LEARN HOW TO TALK/WRITE IN ENGLISH !!! Its driving us buyers insane !!! They sell their product in english countries and expect everyone to know their gibrish language
Nov 07, 2010 | Pioneer Car Audio & Video
My Pioneer AVIC Z2 can only hear sound when radio is on. I can play dvd and cd but no sound. Can someone help me please????
your blue wire(power antenna) is connected to your factory amp. this wire only sends out audio when the radio is on(power antenna)
disconnect this wire and hook up the blue/white instead
problem solved
Kieran
Aug 20, 2010 | Pioneer AVIC-Z2 Car DVD Player
I WANT THE SOFTWARE AVIC-DRV02 CARROZZERIA
I have a solution for you problem, contact this person and tell him thats its jolly who refered you. pr0n@mail.ru, he will be able to post to you an activation dvd for a nominal fee.
Nov 01, 2009 | Pioneer Car Audio & Video
Pairing with a nokia n73
how to do "master reset"for pioneer?
Jun 08, 2008 | Pioneer GPS AVIC-X1 car radio
Car Audio & Video Logo
62 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
