My terestrial dtv does not show me all channels it gives me an error message channel is encrypted what do i do
SOURCE: DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Posted on Apr 16, 2008
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
  • 92 Answers
SOURCE: I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Posted on Jun 20, 2009
  • 6 Answers
SOURCE: Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
pabloloco
  • 2335 Answers
SOURCE: SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Posted on Dec 26, 2009
My tv says no signal when I scan terestrial
you have to have an antenna hooked up to find open air channels
Feb 03, 2015 | Televison & Video
How do I access DTV channels? It always indicates 'Database Empty'
When you set up the tuner select analog + DTV and then do a channel search.
Jul 10, 2014 | Sharp LC32D44EBK 32 in. LCD TV
Can get only 1 channel to program on my toshiba
hi if the tv has dtv just select air digital only thanks
shaun
Mar 25, 2017 | Toshiba 40RV525U 40 in. LCD TV
My mintek dtv-373-d is stuck on encrypted channela nd will not do anything else. I can't get the menu to come up or anything to change. help
I'm assuming you have Cablevision. This is becoming a known problem with their broadcasting system. They have been upgrading and it has been causing the TVs to freeze up on a specific channel .
Simple way to fix it:
1. Unplug tv
2. Unplug coax from tv
3. Plug tv back in
4. In the Menu go to Setup > CH setup > CH Memory > Cable (digital)
5. Enable channel skip for channel that it is currently stuck on
6. Push Menu to exit
7. Change to any other channel
8. Reconnect coax to tv.
Followup:
Avoid this channel and go give Cablevision a call and let them know about it. They won't do anything to fix it until they get a certain number of reported issues about the problem
Dec 08, 2010 | Mintek DTV-373-D 37 in. LCD HDTV
Sharp dtv e202 error was received
Try just changing the channel to the one set up to receive broadcasts. That worked for me-- the TV was working great until I pressed Input and for some reason that changed the channel away from channel 60, which is the one programmed to receive broadcasts from Dish Network. When I entered 60, the message went away and I got my programming back.
Nov 07, 2010 | Sharp Aqous LC-26D5U Television
I'm not able to connect my Lenovo laptop with my Linksys WRt54G wireless router. The Access Connections software on the laptop gives the following three (3) error messages: "Verify that the encryption...
Temporarily connect to the router with a cable and reconfigure it to use a different wireless channel. While you're there, this is a good time to change your security mode - WEP is dangerously weak and you should switch to WPA unless you have a very good reason not to.
If all else fails, there's a reset switch (hidden inside a hole) on the back of the router.
Oct 12, 2009 | Linksys Wireless-G WRT54G Router
Direct TV ''Program not available'' but should be
Define "Lost." if you manually tune to the channel, whats there. By manually tune I mean punch in the channel number on the remote itself instead of using the guide or channel up/down buttons.
If the channel is there but not on the guide, you have set a custom guide and would need to go into your guide setup to change it back to "All Channels."
If you do not have apicture on the missing channel, reply back with the channel number and the error message at the bottom of the screen.
Mar 22, 2009 | Directv D12-300/100 DTV Receiver
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
