How to self troubleshooot backlight that comes on momentarily then shuts off
  • Televison & ... Master
  • 6,694 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 16, 2016
Is there a feedback circuit that is shutting down the high voltage power supply?
May 11, 2016 | Samsung LN46C630 TV
Having same problem where TV standby light comes on and logo appears momentarily then TV does not come on fully (backlight it on slightly).
Hello
You have to troubleshoot from its backlight inverter board itself. That is the first possible cause tho this fault to LCD TVs. If backlight inverter board have shorted inverter transormer [wnding short], the inverter board will take tremendous current from power supply, and this can lead to a momentory logo display and then shut down. The second possiblility is with its main digital board. In both cases, the respective board should be replaced as card basis, as there is no repair to these boards.
Feb 23, 2012 | LG 32LH2000 32 in. HDTV-Ready LCD TV
Black screen , red standby light flashing 4x repeatedly, unplug it and the green light comes on momentarily then resorts to 4 red flashing lighrts again. Sony KDL-40V2500 approx. 4yrs old. HDMI cables are...
4 blinks indicated of backlight malfunction. The unit shutsdown to avoid overload to the inverter board.
Check the backlights, busted backlight has a physical indication of fault like blackened end, crack end. You must replaced the busted one and your unit will back to normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 16, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Monitor is blank. comes on momentarily when i reboot but goes back blank
The problem can be the backlight inverter circuits, bad caps in the power supply, or bad lamps. I would inspect the caps first, look for caps with bulging tops, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 12, 2010 | Liquid Video L17LCD2 17" Flat Panel LCD...
Turn TV on. Turns self off. After many times, if picture comes on, Tv seems OK. All ready paid $350 to fix once 14 months ago.
Having in mind that a generic lamp will give you 4500 to 6500 lamp hours and the Phillips will give you 6000 to 8000 lamp hours, For what you discribe above the could be your problem, I did some research and you can find the best price for lamps http://www.discount-merchant.com/?click=52978 and they have free troubleshoooting
Regards
Nov 18, 2009 | Sony KP-51WS500 51" Rear Projection...
I same problem
The lights inside the LCD screen are connected in series, if one fails the screen will light momentarily and then shutdown.
What's the LCD model number?
Sep 28, 2009 | Televison & Video
Video shows up momentarily then disappears audio works fine westinghouse flat panel
This is a backlight or inverter (power supply for backlight) failure.
These parts may be availble. The backlights are difficult to replace. If not careful, you will break the LCD Material of the LCD Panel when replacing backlights
May 04, 2009 | Westinghouse SK-32H240S Television
Compaq V2000 Display blacks out
sounds like the backlight has gone....test with an external monitor....if the external monitor works without any problems...the backlight has gone...better to get a professional to do this as its kind of fiddly and involves taking the screen apart
Dec 22, 2008 | HP Compaq Presario V2000 Notebook
When i boot up my desktop the monitor comes on then goes off, it come back on momentarily when windows starts up and then goes off again. i can turn the monitor power off then on again and it comes on for...
Your backlight might be dead. Try using a flashlight to see if you can see a screen
when it turns black. If you can, its a backlight problem. What model of screen do you have?
Oct 25, 2008 | Computers & Internet
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
