I have already changed the heat sequencer&limit switches still no power to the sequencer and I'm getting 37voits @ thermostat
Central electric furnace, model# EB17A
  • Heating & Co... Master
  • 1,277 Answers
37 volts is way to much. Verify your transformer is set to proper voltage, 208 or 240. Then verify 24-27 volts on r terminal. Wire nut red green and white at stat to bypass tstat, then check low voltage to sequencer. If its anything other than 27 you have a bad wire or possibly a bad board. Not sure how your power gets to sequencer. Make sure you are testing sequencer on each side of coil, power and common, not power to cabinet. May have issue in common wire. Or try both P&C OR P TO cabinet
Posted on Dec 17, 2016
Central heating not working but hot water is ok.
If when you turn power off you wait a while it is probably not the central system coming on. You have a triple aquastat that maintains a temperature level needed to provide hot water. but you are not getting the thermostat to operate the central heating. The thermostat is a switch that operates by temperature. if you have tried raising the thermostat and the system did nor kick in. try jumping the thermostat terminals in the aquastat . if that works then the problem is either in the thermostat or the wiring to the thermostat. also with a electrical tester." while the thermostat is jumped" test the c1 and c2 terminals to see if power is going to the circulator. If not then you need a new aquastat. if you have power and the pump is not moving water replace it.
Oct 13, 2014 | Water Heaters
Honeywell thermostat will not work when put on automatic
Depends on what type of heat you have...if it is electric, it could be your thermostat (some electric heaters use contactors & rely on the thermostat to switch the fan on). Heat pumps also use the thermostat to switch the fan on in heat & cool mode. Most electric furnaces use a sequencer to switch the low speed of the fan whenever there is a call for heat. Gas furnaces use either a fan/limit controller (if the unit is older) OR a circuit board based on time (after the thermostat calls for heat). SO depending on the type of system you have, it could be a bad sequencer, controller, relay, thermostat, or control board. Hope that helps.
Dec 17, 2013 | Heating & Cooling
My honeywell thermostat will not let the fan blow if it's on automatic
Have Coleman mobile home unit electric furnace changed sequencer and limit switches strips stay on after cycle and also run with unit switched off
This is the one where you have to lay on your head to work on it, I assume? Has to either be a bad sequencer, or the thermostat/thermostat wiring. If all the strips stay on, something is miswired, or your thermostat is keeping them on.
Nov 05, 2013 | Heating & Cooling
I'm getting hot water for 2 minutes , then it gets cold
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
Hope this helps out
Feb 02, 2011 | General Electric GE SmartWater Household...
Working on a coleman 3ton split unit in a mobile home, when thermostat calls for heat, the heat strips come on and blower comes on. heat strips go off before the thermostat is satisfied and the blower...
Probably a bad limit switch on the strips or the heat sequencer/relay is falling out after continued amp draw. I would lean toward the heat relay/sequencer. Havent heard of any problems with coleman limit switches. These units were prone to get water inthe electrical compartments due to the evap coil being right above it. Check to see where the power break is starting at the strips and working backwards throught the circuit. That will tell you for sure. Make sure you have 24v going to the heat sequencer too.
Jan 19, 2011 | Coleman Heating & Cooling
How do I wire a central heating room thermostat
You didn't mention if you had electric heat or gas heat. If you have electric heat you must move a wire on the thermostat to make the fan come on. Most all wall stats come ready for gas heat. No need to make a wire change for gas. Anyway I have a diagram of a typical central unit HERE
Nov 19, 2010 | Heating & Cooling
Wiring heat only thermostat to inter therm central electric furnace had to replace fuze block, limiter, and sequencer thermostat only has one red wire and one white wire
I am trying to install a Honeywell VisionPro 8000 thermostat for my Intertherm Central Electric Furnace but I am having trouble getting to work any suggestions?
Oct 06, 2010 | Heating & Cooling
The high limit thermal switch on heater burns out.
There are two thermostats, a 'limit' or 'operating' thermostat which turns the heating element on and off, and a 'high limit' or 'safety' thermostat which oversees the 'operating' thermostat by opening and removing power to the heating element when the upper limit temperature is reached. Basically, the only difference between these two are the temperature ratings. The 'high limit' is higher than the 'operating' thermostat. The thermal fuse is the last resort protection.
First and foremost, you must know that every inch of your exhaust vent pipe is clean.
Usually, a bimetallic limit switch will degenerate in the direction of too low of a temperature range because as the parts wear out inside, the mechanical tolerance widens (the tiny rod that pushes the contacts together gets shorter).
The high limit thermostat is by the thermal fuse. The operating thermostat is in the blower housing.
Check the fan impeller for broken vanes and lint. The impeller is directly coupled to the motor and should not turn without the motor. The fan housing and ducting should be free of excess lint.
Good luck.
May 02, 2010 | Samsung DV316LES Electric Dryer
My kenmore 70 series dryer isn't drying - changed the heating element, changed the thermal fuse, and the high limit thermostat. Lint is cleaned and the motor is running.
Are you getting any heat at all? Did you change the thermal cut-off which is mounted near the top of the heater box? This is the only other piece in the heating circuit. If you changed it already you could have problem in the timer or in motor. There is a switch in the motor that controls heat also.
May 26, 2009 | Kenmore 62602 Electric Dryer
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
