Question about Cuisinart Food Processors
I can't figure out how to remove the large main pusher from the cover of my Cuisinart Elemental 11 Food Processor. I can't find a release mechanism
SOURCE: Cuisinart Prep 11 Plus Food Processor - Help!
Not sure if you found the solution by now but we recently had a similar issue. Make sure the bowl is put on such that the handle is facing the front of the processor. There is a little black button that gets depressed when the lid gets put on. We had to get the thing to work one night and spent hours trying to get the processor on and then trying to get a blender to work before finding the problem.
Hope this helps.
Posted on Nov 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Posted on Mar 17, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Plastic housing cracked Cuisinart DFP-11 Deluxe food processor
Cuisinart does, in fact, have the replacement bowl parts for the DFP-11
Posted on Mar 20, 2009
SOURCE: need manual for food processor
Found it at:
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DLC-10S-_E
Posted on Sep 15, 2009
  • 3 Answers
SOURCE: locked in blade
My old Cuisinart has this problem because the motor shaft and the corresponding socket on the cutter are worn. The shaft has jammed in the cutter. To un-jam it, stick a bar of wood behind one blade of the cutter (I use the wood handle of my dough whisk) and give it a light, sharp tap with a hammer. Check after every tap to see if it is loose, if not do it again. You want to tap against the back side of the cutter, not the cutting edge side. The socket on your cutter may be cracked, allowing it to open up and slip (and jam) under the stress of cutting. You'll probably need a new one. If the motor shaft is also worn, that can also be replaced. The new part is about $10. I got a few more months of life from my cutter by reinforcing the inner socket with a thin plastic tube from the barrel of a syringe.
Posted on Jun 12, 2010
How do I remove the cover from the bowl on the EV-11PC9?
The bowl cover needs to be turned (rotated) clockwise a small amount to release the catches on the bowl.
Easiest way is to grasp the bowl handle and press to the left with your thumb on the extension of the cover that goes over the top of the handle.
Remember that the pusher MUST be removed from the cover to do this because of the interlock that goes down through both the cover and the bowl handle.
Oct 10, 2011 | Cuisinart Ev11pc9 Food Processor
I cannot get the top off the main cylinder on my DLC-85
The pusher sleeve has what I describe as a plastic "clip" on it - if you look carefully at this clip, there is a circle that says "Press Here". If you press on that clip, the whole pusher sleeve will ocme out, and then you will be able to remove the lid.
May 02, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Food processor does not work but light is on
Put the work bowl, lid, and pusher on one piece at a time - handle of work bowl faces the front of the food processor, hollow feed tube faces the back, and the sliding lock switch on pusher sleeve faces the front. Should turn on.
If it doesn't, test the motor - remove the work bowl and other parts completely. Plug the base in and turn it on, and use a pen to push in the dark grey or black button on top of the base - if it spins, the motor is still good - you may just need a replacement part. If it doesn't make a sound, it needs to be sent in to Cuisinart for repair.
Mar 29, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
None of the buttons work on my Power Prep Pulse 11-CUP
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart prep 11 Plus won't run.
Remove the work bowl completely and separate the work bowl, lid and pusher sleeve. Plug the base into the wall outlet and press the on switch. Use a pen to depress the dark grey or black button on top of the base of the processor. If you don't hear a sound, then call Cuisinart and get it repaired. If you do hear a sound:
1. Put the work bowl on first, making sure the handle is facing front
2. Put the lid on, making sure the hollow feed tube is facing the back of the food processor
3. Put the pusher sleeve in, making sure the sliding lock switch faces toward the front of the processor
Turn the machine on - it should now be working
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart DLC-2 Mini Prep Plus Food...
Need a instruction book or manual for cuisinart 7 cup food proces
All manuals for models made in last few years are on Cuisinart website.
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
Dec 07, 2008 | Cuisinart DLC-5 Food Processor
Won't turn on
-Tha Mp3 Doctor
The manual is available on Cuisinart's website
Nov 27, 2008 | Cuisinart DFP-11 Deluxe Food Processor
CAN'T GET TOP ON TO OPERATE AND CANNOT FIND CD FOR 14 CUP CUISINART FOOD PROCESSOR
Do these directions in reverse - (the how-to DVD is generic - not for each individual Cuisinart food processor):
-Tha Mp3 Doctor
Apr 13, 2008 | Cuisinart Limited Edition Metal MP14 Food...
DLC 7 pro
-Tha Mp3 Doctor
Oct 18, 2007 | Cuisinart DLC-8S Pro Custom Food Processor
Food Processors Logo
56 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Donni Steen
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
