My sanyo/panasonic tv turns itself off after turning it on and it clicks all three times then stays off. What board do I replace? MD-50H12NBC.....ET95306682.....J4FH
  • 1894 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
was that capacitor damaged?
Posted on Jan 11, 2008
  • 83 Answers
SOURCE: TV Problem
SANYO MIGHT HELP YOU BUT YOU NEED TO CALL IMMEDIATELY BEFORE MORE DAYS GO ON..
Posted on Feb 21, 2008
  • 6 Answers
SOURCE: my 40"samsung LCD turns on/off 3-4 times before staying on
You need to change the 1000uf caps in the power supply. only if you are handy with a soldering iron. Take back of remove psu. You will see them bulging at the top. Think there is 5 to change :)
Posted on Jun 17, 2009
  • 12 Answers
SOURCE: 3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Posted on Dec 16, 2009
Testimonial: "while we did not unplug the set, we let it sit for 2 days and we were able to turn it on by the remote & manually....does that still sound like P/S"
  • 4 Answers
SOURCE: sanyo 50 inch plasma tv won't turn on. a couple of
its your main internal power supply board
Posted on Feb 15, 2011
I have a Panasonic TC-P65VT60 Plasma TV that seems to randomly turn itself ON. What PC board is causing this?
That is a plasma and usually power supply board. ebay search your model number. Also look for blink codes on front if it locks up. lastly check for software upgrades for you model thru google
Dec 02, 2017 | Panasonic Televison & Video
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
Have a sanyo 50" plasma
This tv problems are related to powering up the tv and sustancening the tv power source to the tv itself.Replaced the tv sub power supply board where the a/c power cord plug into it.Try website like Ebay.com to buy a whole new refurbish sub power supply board for the replacement.
Sep 06, 2011 | Sanyo DP50747 50 in. Plasma TV
My panasonic television blinks a red light three times and then will not turn on. Why is it doing this, and how do i fix it?
Tries the tv unplug,replug it back in like an hour later.The tv now is resetting itself back to the factory setting.The tv now should work.Not,than the tv power supply board is dead.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Tv takes 20 minutes to turn on, keep hearing a clicking sounc
Ur tv the Ballast board the help to turn on the tv projection bulb is dead.Try website like Tvrepairworld.com to buy the Ballast board for the replacement.The Samsung/Akai tvs use the same Ballast board.When in the website go to the menu that said Samsung/Akai circuit boards.Pick that option click on it,u will see a picture of a Ballast board look like.
May 31, 2010 | Samsung HCN4226W 42" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
What does it mean when my plasma tv turns off by its self? its a panasonic viera plasma tv have had for bout two years
Basically when it turn itself OFF automatically all the time, the TV goes into "Protection Mode". This happens when there is a damaged circuit board inside the need to be replace and turn itself OFF to protect the other ones from being damaged.
A TV service tech will have to look at it to find out which boards need to be replace. There are about 7 different boards in your TV that would cause this problem.
Nov 01, 2009 | Panasonic Televison & Video
Tv problems
Unplug the three red-blue-green plugs nest to the convergence amps. If the unit powers up and stays on the picture will look bad but will confirm that the convergence amps have failed...
Replacing the amps and one or more resistors in the yoke return will restore the set to normal operation..
Use only Sanyo original Ics..
Bill
Oct 11, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
