Question about Fisher and Paykel Ovens
Fisher and paykel saffron how do you use the timer for the oven?.
5 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Posted on Jul 14, 2010
SOURCE: I have a Fisher and Paykel Paprika oven and have
Hi you need to down load the manual and look on page 5 to reset. http://www.fisherpaykel.co.nz/admin/pdfs/pdf_usecares/599450A_RA_Freestander_ugm_NZw.pdf
Posted on Jan 20, 2011
  • 251 Answers
SOURCE: I have a fisher & paykel paprika and i cant get
Hi - Are you able to provide model number of the oven - or describe the front controls as they have about 6 different types of controls regardless of the brand name 'paprika'
cheers
Posted on Jul 01, 2011
  • 48461 Answers
SOURCE: The oven light comes on but does not heat up and the fan does not turn on
function dial needs to be on bake I believe
Posted on Jun 09, 2015
How do you start the clock on Fisher & Paykel
Fisher and Paykel does not know that model number. Could you recheck it please and advise us?
May 09, 2016 | Fisher Ovens
How do I turn off Auto on oven
Hi Anita,
A quick search of Google for an answer to my question "Turning Auto Off on a Fisher and Paykel Oven"
With little more detail from you like model and if AUTO Off as with Timer I could pin point it, i..e.be more accurate.
So if my guess is correct than it should be on the Analogue/Analog Timer Knob OR if electronic somewhere on the keypad, electronic touchscreen? pad....meaning set it to MANUAL....have you tried that?
Cheers
Nov 02, 2014 | Fisher and Paykel Ovens
cheers
Jul 01, 2011 | Fisher and Paykel Ovens
Hi.. I have a wall oven fisher & paykel model 600e and after my girlfriend tried to use it pressing all the buttons without knowing what she was doing the element is not heating up anymore :( what...
The electronic timer must be in manual mode for the oven to work. Turn the oven on. Play around with the clock/timer buttons using as many combinations as you can. When the oven indicator light comes on the clock/timer is in manual mode. This could take 5 minutes or more. Be patient.
Mar 01, 2011 | Ovens
I have a Fisher & Paykel OS302. The temperature and oven mode selects are dead, no LED display, no operation. The clock module is working. This happened all at once, I tried to turn it on and both...
This sounds as if the electronic clock timer is in automatic mode. It must be in manual mode for the oven to work. Turn the oven on and play around with the timer controls/buttons. When the oven indicator light comes on the clock is in manual mode.
Feb 26, 2011 | Fisher and Paykel AeroTech OS302 Electric...
The timer sound on my classique oven has suddenly become so soft I can barely hear it
turn mains off for 1 minute nd then restart it will default to orignal settings
Oct 28, 2009 | Fisher and Paykel AeroTech - OS302M...
Fisher and paykel B1600E multifunction stove manual
I have a PDF copy of the Fisher & Paykel B1600E user manual
Nov 12, 2008 | Fisher and Paykel AeroTech - OS302M...
Ovens Logo
26 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Joseph Hoffmann
Oloyede Monsuru
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
