Question about Garden
How to dismantle a Hunter irrigation control system for repairs
4 Suggested Answers
SOURCE: Instructions for garden watering system Hardie Irrigation
WIRES CONNECTION
Posted on Mar 08, 2010
tbreeze47
  • 3083 Answers
SOURCE: I have installed a Hunter
So the mv and c are supplying power to the transformer/relay and out of it, but the pump won't start until the relay is forced.
I'm thinking the relay contacts are oxidized, and need to be cleaned. When they have oxidation, current goes up, and voltage might appear ok. If any start capacitors are in the circuit, they can be faulty, breaking down under a load, while reading ok. I haven't heard of any caps in these systems, but just in case.
The following blog may help you- it's about different controller situations:
http://forums2.gardenweb.com/forums/load/water/msg121639307045.html?9
Hunter's website has some things to check concerning the controller:
http://www.hunterindustries.com/resources/library/product_technical.html
Looks like it could be microprocessor lockup. It's quite a process, but here's what they say is the fix:
http://www.hunterindustries.com/resources/library/Technical/200611_hdln_micropro.html
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 14, 2010
SOURCE: owners manal for a hunter
hai....
am uploaded the full pdf file of owners manual for it u can download it from http://hotfile.com/dl/75457050/e9e8b4b/user.pdf.html
Posted on Oct 12, 2010
Hunter irrigation system.
yes. so whats up with it?? how about adding information here?? when you ask any question here you need to put as much info as possible. questions are not threaded like normal message boards so info and questions get lost in the mix around here.
Sep 16, 2017 | Hunter Garden
How do I get my Hunter ICC irrigation control box to turn on?
Check batteries with tester. Check internal fuse (sometimes same compartment as batteries. May have have to spend the $20.00
Jan 18, 2015 | Hunter ICM-400 ICC 4 Station Sprinkler...
Hunter node _ Running water all the time
Solenoid Valve set to manual on St Valve to off position
Mar 31, 2013 | Hunter Industries Hunter NODE-100 Single...
Irrigation valve vibrates when opening.
Take apart and clean spring /diaphragm is sticking
Clean unt out
Feb 18, 2013 | Hunter Industries Hunter NODE-100 Single...
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Intermatic R8816P101C -...
Owners manal for a hunter xc irrigation controller
hai....
Oct 12, 2010 | Computers & Internet
I have installed a Hunter psr22 pump start relay and connected it to a Hunter src irrigation controller and when I cycle the irrigation controller to manual all stations it will not start the pump. There...
Sep 14, 2010 | RTO Hunter Psr-22 Pump Start Relay
Hunter sprinklers vs rainbow sprinklers
I work with both Hunter and Rainbird irrigation components. Both companies have good products. But, I prefer Hunter for the sprinkler heads and Rainbird for the controllers and valves.
Oct 30, 2008 | Ace Hardware Hunter& Low Profile III...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
