Question about Crown CTS600 2-Channel Amplifier
I have a Crest FC 440 and need a schematic. - Crown CTS600 2-Channel Amplifier
I need a pic of wire configuration to a 1971 440 axial flow panther with a kawasaki engine
Do you have a smart phone then be smart and ask your phone to show you a wiring schematic for a 1971 440 axial flow panther with a kawasaki engine
Feb 14, 2015 | 1971 Suzuki T 350
What is the voltage of transformer of crest audio vs450
Power Supply (factory configured): 100V-240V, 50-60Hz
You should only need a standard power cord (like the one that fits the back of a computer).
CREST AUDIO VS450 Specifications Page 2
Feb 04, 2015 | In Store Used Used Crest Audio Vs450
Plastic in crest toothpaste?
There are petroleum-based ingredients in Crest Toothpaste, specifically sodium saccharin. (Petroleum is used to make plastic and engine fuel). However, there are no hard granules of plastic in the paste.
Mar 26, 2014 | Computers & Internet
I have a Crest Audio V900, a set of Bose 901, a Gemini EQ-3000. Do I need a PREAMP? Or can I hook up the Crest AMP to the Equalizer?
You could use the EQ but it won;t sound as good as it will with a pre amp and also could make it a bit trickier when adjusting the volume and getting it to sound right.
Mar 10, 2012 | Crest Audio Audio Players & Recorders
Am a technician, i havent dealt with crest sound before. my client's amp has lit the clip light, control light but not the signal light. initially it was ok but all of a sudden, they went to operate it and...
The signal light is triggered by the presence of an audio signal on the input side and should be visible. With the clip light on without any input signal, suggests a problem in the front end. This is not an amp to be worked on without a schematic. Try getting the prints for this from Crest (Peavey owns them now).
Dan
Feb 17, 2011 | Crest Audio CA 6 Amplifier
Every time I turn the amp on it shuts its self off.
disconnect all speakers and test if the problem corrected you will have a problem in your speakers(either wire or speaker itself)-try to connect the speakers one by one until you find the bad one and change it--if all above does not work send your amp to service center near you
Mar 30, 2009 | Crest Audio CPX-900 Amplifier
No power
These amps are very compact and are not the easiest to work on. If you are not experienced at repair, I would not recommend you start here. Where are you located?
Dan
Jan 13, 2009 | Crest Audio CPX-900 Amplifier
Magic Deluxe
Try asking Saeco USA. I called them for a schematic of an old Super-automatica. It was very helpful. They faxed it to me.
Saeco-USA
7905 Cochran Road Suite 100
Glenwillow, OH 44139
Tel. 440-528-2000
Fax 440-542-9173
E-mail: info@saeco-usa.com
Nov 29, 2007 | Saeco Magic De Luxe Espresso Machine
Crown CTS600 2-Channel Amplifier Logo
66 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
