Question about Panasonic CQ-VD6503U Car DVD Player
Screen is distorted!!!! HELP!!!!!!!!
Hello all,
my units lcd display is distorted. Does anyone know what the problem is? It's not as bad when it's cold but it's still distorted. When the unit is on for about 2 minutes, it gets bad. This happens in any mode. It looks like double vision for the most part then gets bad fuzzy lines
  • lenso01 Jan 06, 2008
    This is a common problem for this model. I saw so many fuzzy screen panasonic 6503 on ebay. It had fuzz screen out of box. I'm looking for a solution too.
    Scholar:
  • 67 Answers
Bad LCD Display. If Have repaired 4 units in past year with this failure. Looks like video is out of sync. Failure can be Intermittent or Constant. Any Questions kstahl65@att.net
Posted on Jan 06, 2008
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Laptop LCD/Display Problem, Green and Pink Tints???
Their are a couple things that could be causing this, My first thought is that the screen its self is damage. A LCD screen is composed of millions of tiny pixels so when some fails others will still work.
That other thought is that the GPU or video device on the laptop could be failing and creating video problems. Have you tried closing the laptop and opening it agian, this would help rule out a bad cable connection.
Dec 24, 2013 | Computers & Internet
How to Degauss
LCD flat panel monitors do not have or need a degauss function. The older CRT monitors had the degauss button to remove any magnetism that built up in the metal frame that would cause distortion. LCD monitors do not rely on magnetic fields so no degauss button. If your display is showing strange patterns and text the most likely cause is a bad video card. First try a different monitor on your card. I would bet the display is bad on it too. It you find this problem just replace your video card and the issue should go away.
May 16, 2013 | LG Computers & Internet
The screen of the Garmin nuvi 1390 lmt became blurred. When I tried to press the screen tightly with fingers, it displays correctly and after I remove finger it agin blurs. Please help me fix this issue.
Any distortion in the picture of the LCD display points toward a defective display. It is possible there is a bad connection between the LCD flex cable and its connector on the printed circuit board but to to check it would require taking the unit apart.
More info on LCD problems can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Mar 21, 2013 | Garmin nuvi 1390T Car GPS Receiver
No backlight
A) Replacement LCD screen backlight could be bad.
Happens. Sometimes you get a bad part. (Bad LCD screen assembly, in this case)
LCD screen may not be the correct one.
http://support.gateway.com/s/Mobile/2008/GodzillaFX/2528410R/2528410Rsp2.shtml
http://support.gateway.com/s/Mobile/2008/Godzilla/2528407R/2528407Rmv.shtml
A screen Inverter, and an LCD screen; are a MATCHED unit.
B) Screen Inverter:
May be bad, or the Wrong one
C) You may not have the screen Inverter, connected correctly to the Backlight.
Connections aren't tight.
D) The Display Cable TO LCD screen connection may not be tight, or correctly connected.
I know the display shows graphics, but a poor connection of Display Cable to LCD screen, can make the Backlight dim out.
I'm betting it is a poor connection, or the wrong screen Inverter, or wrong LCD screen.
Regards,
joecoolvette
(Be shame to kick that laptop to the curb. Nice laptop)
Jan 07, 2013 | Gateway P-6860FX Notebook
Hi, I started to have an issue with a display of my Tecra M5. The laptop is 2 years old and there has been no problems with it before.. Last week I attached a 32" LG LCD TV to my Tecra as an...
the 32 inch LCD may have a lower display resolution that the LCD on your system. Ensure that the display settings for the LC are at the MAX resolution and 60 htz
Jul 31, 2011 | Toshiba Tecra M5-S433 Notebook
Corrupted display on LCD monitor.
Those lines on the right side show sign of damaged T-CON board, part of the LCD panel assembly, nothing you can do but getting the new LCD panel. The bright section on the screen looks like the backlight lamp reflector got out off the guide channel.
http://s807.photobucket.com/home/budm/allalbums
Sorry for bad news.
May 18, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Laptop only displays image on 2/3 of lcd screen.
Try installing the latest video driver. Download it from the HP WEB site and make sure the video driver matches Windows XP or Vista that is installed on your laptop.
Sep 06, 2009 | Compaq Presario Notebook
Sony Bravia 46S2010 no picture only glows but, only sound on
sound like you had problem with the lcd display panel. The Tcon had problem that attack to the panel.
Mar 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Can you please, please help, my beloved Canon Power Shot A75 (purchased in 2005 in France) has developed a LCD display problem when turned on. A few months ago the screen distorted with lines and now the...
This is most likely a CCD problem that is being repaired free by Canon. I don't know where the French repair center is but you might find it on the internet. For more details about the free repair, go here: http://www.imaging-resource.com/badccds.html
Nov 18, 2008 | Canon Cameras
Panasonic CQ-VD6503U Car DVD Player Logo
174 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
