Question about Rheem Water Heaters
What is error code 76 on a Rheem tankless hot water heater that has propane connection?
  • 1,381 Answers
Communication Fault with Remote Control. At a minimum check the following: 1. Check remote control wiring for loose or damaged connections. 2. Bypass remote control cable by connecting remote control directly to remote control terminals on PCB. Replace cable if found to be faulty. Yes Either the wiring or the remote control is at fault. To rule out the wiring, disconnect the remote control and use a short, good jumper wire and connect directly to the remote terminal on the PCB. If the unit works using the remote, then the wiring is at fault. If the unit does not work, then the remote is at fault. Did the unit go to main burner? No Replace the Printed Circuit Board Remove remote control wires from wiring terminal on the PCB. Plug unit in and open a hot water source.
Posted on Dec 16, 2016
C4 76 error code on richland waterheater
Richland tankless is made by Rheem.
C7-76 is communication fault with remote.
Turn off power at remote and wait 5 minutes, turn power back on at remote, and see if problem clears.
If problem continues, read below:
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, typical maintenance manual:
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Tankless water heater, more than any other type of heater, need to be maintained.
Maintaining tankless will probably not affect C7 76 fault code, but can prevent many other common error codes.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Sep 14, 2011 | Rheem Tankless Hot Water Heater...
Tip
Get hot water from your Rheem tankless during a code 76 error
This doesn't always work, but on the Rheem tankless Gas/Propane water heater, if you're experiencing a code 76 error; disconnect the remote control unit (either from the water heater or the remote) by lifting the wires for the remote connection. Typically you'll get a C1-C8 error code, followed by a code 76; if you're getting a straight code 76 and nothing else, this procedure probably won't work.
Code 76 is a total power supply failure on the printed circuit board (PCB) assembly, which is the communication/power supply for the remote control unit. But, if you're getting a supplemental code (C1-C8) this procedure will most likely supply you with hot water until the replacement PCB arrives.
on Dec 01, 2009 | Rheem Tankless water heater for 1-2...
Have a Rheem PTG-74PVP tankless water heater. Shuts off after a few minutes while taking a shower. Get a code 76 C8
Before calling service technician, open following links for troubleshoot resources including error codes and rheem chat, and typical scheduled maintenance:
Error 76 can mean communication failure between tankless and remote control, which can include bad remote control, bad wire, bad wiring connector, or PC board failure.
Disconnect remote control and see if tankless will work.
Error C8 76 can mean PC board failure.
Contact Rheem and/or service technician.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 07, 2011 | Rheem Tankless Hot Water Heater...
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
http://waterheatertimer.org/pdf/Error-code-13.pdf
Aug 12, 2011 | Rheem RTG-66DVN Direct Vent Natural Gas
Remote is flashing C8 and 76, alternating. I turn the unit off, then back on, and I get hot water for about 10 seconds, then it goes cold and the same error message occurs. Unit is Rheem Main Remote...
Before calling service technician, open following links for Rheem tankless resources including error codes and Rheem chat.
Disconnect wires from remote to see if system stabilizes. Unit will heat to default temperature without remote.
76 can mean communication failure with remote control
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Jul 31, 2011 | Rheem Tankless Water Heater Main Remote...
Getting a 76 flashing on my Paloma PTG-74XP tankless water heater
Error code 76
http://waterheatertimer.org/pdf/Rheem-Tankless-Fault-codes.pdf
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Mar 30, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
Rheem tankless propane hot water heater error code C7. Cant get hot water. It keeps shutting off and then once turned back on wont work and gives the C7 code. What does it mean?
Use following link for Rheem tankless troubleshoot: http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
I believe error code C7 is same as error code 76
Add a comment for more free help.
Feb 17, 2011 | Rheem Tankless Hot Water Heater...
My tankless is shuting off or flashing C4 and/or C7
Feb 09, 2011 | Rheem Tankless Hot Water Heater...
My hot water heater keeps kicking off and the theramsatic is flashing C7 76. How do I reset it?
Jan 31, 2011 | Rheem Tankless Hot Water Heater...
Water Heaters Logo
409 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
