Question about Intex Pool & Spa
What is error code e95. I have a intex hot tub only 2years old and can not get this code off. How can I please fix this??
I'm getting a code eE95on me intex hot tub. How can I fix this???
2 Suggested Answers
  • 990 Answers
SOURCE: My electric went out for 24 hours. I hooked up my
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Posted on Dec 16, 2009
My intex purespa hot tub model# SJB-HS-10 is flashing E96. I called intex, and they would not even help me trouble shoot it. I was told to buy the whole new control.
Answer
E96 means the PureSpa is experiencing a system error. If the control panel displays this error, turn off the system and unplug it. Plug the unit back in and restart it. If the error persists, turn it off and unplug it. After unplugging it, unscrew the B and C connection until water starts to leak out. Do not unscrew them to the point that they come off of the tub as you can lose all the water in the tub. Loosening them until the leak will release any air from the control base. Tighten the connections and restart the unit. If problem persists, please contact the Intex Service Center for assistance.
Dec 04, 2017 | Lands Phones
My intex hot tub has a leak int he seam on the inside, how do I fix it
I would check out flextape.
https://www.neweasy.com/product/flex-tape/?ref=astvdb
Oct 06, 2017 | Intex Pool & Spa
I get a E90 code on my Intex Hot Tub and it is not heating the water.
recirculation pump or heater element or temp sensor
Nov 20, 2016 | Intex Pool & Spa
What chemicals do I need in my intex inflatable hot tub
Hi, according to this site How to Treat Your Hot Tub Best Hot Tub for 2014
First check th pH levels with the pH level checker.That is pretty straightforward and should be included in instructions with your pH checker (which may have come with your hot tub)
It's good to do a chlorine shock once you fill the hot tub with water.
So what will you need?
pH tester/pH tester strips
chlorine
And chemicals for balancing ph ... pH+ and pH- which you will surely find in a shop with pools.
Each of this should come with instructions.
Apr 09, 2016 | Intex Pool & Spa
Why does the bubbles come on when I turn on the heat on Intex PureSpa Hot Tub
im sorry to let you know, but water intrusion (splashing) to inside the control box and hence all sort of "gremlin" behavoiur is very common with these units
the perm fix that i have done for this is to replace control unit , have an electrician add longer wires to pump and sensor and i moved control box to other side of patio , where its not as likely to get splashed allso i added a waterproof roof to it as well to shed rain water away from it , so far so good as it's worked ok for four years that way
Aug 31, 2014 | Intex Pool & Spa
What does SPH MEAN?
When you have an SPH error it means you could have an over heated power pack, or you have a water flow issue, or possible damaged equipment. Here is the three trouble shooting items you can look for.
1. Your water temperature is lower then 60 degrees (Turn the unit off and let it cool down and then turn it back on, this may fix the issue)
2. Your water inlet or outlet is blocked or partially blocked (Clean the inlet and outlet of the hot tub)
3. Your heater sensor is not working (you may have to replace the heater element or circuit board)
The SPH Error and how to Fix
Aug 24, 2014 | TheraPureSpa New 2 - 4 Person TheraPure...
Help my intex pure spa ssp-20 has no water flow
Hi does any body else have had this experience Hot Tub Pure Spa SSP-20 LCD Screen thermostat numbers disappearing ie 3 will disappear or the 8 etc then they come back for a while then goes again, hot tub was bought back 30 July 2014. only used it roughly 4 months in total thought it might be because off the heat but to be honest we've not had it very hot here in the west and bearing in mind these come from America which is mega hot ours is still under warranty but cannot seem to get any help with regard to this can it be fixed at all if anyone can advise would be grateful.
Sep 28, 2013 | Intex Pool & Spa
Pool & Spa Logo
682 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
