Question about Intex Pool & Spa
Intex hot tub code e95 how do i fix this - Intex Pool & Spa
Our Intex spa pump will not turn on
does the unit power up if not check and test the ground fault safety plug they can fail --if powers up and pump not working then the your problem is most likely the ceramic rod that holds the motor /impeller in place they have a big problem of breaking and intex doesnt sell a separate pump or the replacement rod the following link can show some quick fix but if you buy a brazing / welding rod the same thickness -home depot sell them 9.99 a box you only need 3" and need to clean flux off
Intex spa E95 cheap fix
Jun 04, 2017 | Intex Pool & Spa
What chemicals do I need in my intex inflatable hot tub
Hi, according to this site How to Treat Your Hot Tub Best Hot Tub for 2014
First check th pH levels with the pH level checker.That is pretty straightforward and should be included in instructions with your pH checker (which may have come with your hot tub)
It's good to do a chlorine shock once you fill the hot tub with water.
So what will you need?
pH tester/pH tester strips
And chemicals for balancing ph ... pH+ and pH- which you will surely find in a shop with pools.
Each of this should come with instructions.
Apr 09, 2016 | Intex Pool & Spa
What does SPH MEAN?
When you have an SPH error it means you could have an over heated power pack, or you have a water flow issue, or possible damaged equipment. Here is the three trouble shooting items you can look for.
1. Your water temperature is lower then 60 degrees (Turn the unit off and let it cool down and then turn it back on, this may fix the issue)
2. Your water inlet or outlet is blocked or partially blocked (Clean the inlet and outlet of the hot tub)
3. Your heater sensor is not working (you may have to replace the heater element or circuit board)
The SPH Error and how to Fix
Aug 24, 2014 | TheraPureSpa New 2 - 4 Person TheraPure...
Pool & Spa Logo
187 people viewed this question
Top Intex Pool & Spa Experts
Level 1 Expert
Jay Finke
Jay Finke
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
