Question about Rinnai Heating & Cooling
Rinnai rdt 600, replacing the fan belt - Rinnai Heating & Cooling
Rinnai R85 starts to warm then stops and blinks 61??
I went to the Rinnai website and this is what I found for error code 61.
Error Code 61 Problem: Fan failure
Solution: Measure the resistance on the fan motor, check the damaged or loose wiring and connections. Make sure that the fan spins freely.
Sounds like either your fan is broken or something is keeping it from spinning freely.
Hope this helps.
Feb 24, 2015 | Rinnai R85ePLUS Tankless Water Heater
I need user manual for Rinnai Fan Heater 2000 RC - 219AC
How to operate Rinnai RC-219AC Fan Heater 2000
Jan 08, 2014 | Rinnai Heating & Cooling
Disconnect the control wires and see if it still does it
Feb 21, 2012 | Kohler Electrical Supplies
I have a Rinnai 516TR showing error code 62
Error Code 62, indicates a faulty fan motor. Which, according to your Owner's Manual, requires a service call by an authorized Rinnai service technician. it may not mean replacing the fan motor. It could also mean a faulty fan sensor.
Hope this helped you. Cheers.
Jul 08, 2011 | Rinnai Heating & Cooling
Rinnai energy saver 1001ft try to on unit power on light shows,fan starts,times out,fan on again then shuts down. no flame indicator showing. problem? regards peter
There are a couple of things that can cause ignition problems:
The exterior direct vent termination may be clogged.
The gas line shutoff is not turned ON or is only partially open.
The filter needs cleaning. Be sure to turn the Master ON/OFF Switch to OFF before removing the filter. Leave it Off until the filter is cleaned and replaced.
All the above problems you can troubleshoot and solve yourself. The ones below, require an authorized Rinnai Service Technician to solve.
Spark ignition failure.
Faulty solenoids.
Faulty Flame Rod.
Hope this helped you to troubleshoot and solve the problem.
Jun 02, 2011 | Rinnai Heating & Cooling
The refrigerator is working but the freezer don't. Is on and it sounds working but the air wont come inside the freezer. traulsen rdt 2-24 dut
check for either a bad evap fan motor or a bad fan delay. It could be an under charged freon level too, but I would check the other items first as they usually go bad more frequently.
Jun 23, 2010 | Traulsen Refrigeration 48'' Wide x 24''...
I have a Rinnai model 2532 Tankless Water heater. When the Bath water is turned on (which is the largest water flow for the water heater)it makes a loud vibrating sound that can be heard through the entire...
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Soution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably mechanically inclined:
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem. Also - the Rinnai pipe going outside is a pipe within a pipe - so its both inlet and outlet air.
Nov 19, 2009 | Rinnai Webstone The isolator EXP tankless...
Heating & Cooling Logo
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
