Question about Air Tools & Compressors
I have Atlas compressor XAS 186 loads up as soon as started
  • 832 Answers
SOURCE: my 1998 atlas copco xas 97 185cfm deutch diesel
Check the Deutch diesel engine controls. Normally with
the compressor at full open, engine must continously run, sionce this is the point where the engine is not
heavy loaded. Check the injection pump as well as engine speed control and the air filter.
Posted on Nov 06, 2009
compman66
  • 169 Answers
SOURCE: the air compressor xats 67 starts, runs but cannot
suspect that the inlet control valve or control regulator may be at fault, but are you sure that your demand is not more than the compressor can deliver? if you close off the service valve will it come up to pressure and idle back as normal? if so then you may have a leak in your system or your demand is to large. But having a knowledgeable service tech check it out would be the next step.
Posted on Feb 16, 2010
  • 243 Answers
SOURCE: starts but can not compress
hi i think the drivebelt for the screw is broken or missing all theeth. when this is, after starting the engine runs at max rpm and no pressure will be built up. to check the belt, wich is behind a plastic panel just behind the compressor oilfilter, its easy to take off the oilfilter, take off the plastic panel, using screwdriver to bend the lips, and look at the belt. very oft its broken and you will find the teeth everywhere in the housing. if the belt is ok, the problem will be in the regulatingsytem, but thats only a smal chance. to change the belt you need a special tool to bring it to the correct tension. you can always ask more info. good luck.
Posted on Feb 17, 2010
Testimonial: "thanks a million times i tried ur suggestions and it worked as the belt connecting the compressor and engine was worn, thanks once more."
  • 3 Answers
SOURCE: hi, i have a xas 146
if its fitted with a water seperator then it may need draining, other than that your oil/air seperator filter may require changing, you will get some water(conensation) as the compressed air heats up and cools down, failing that try an in-line air/water sperator(about 20 pounds to buy)
Posted on Aug 12, 2010
SOURCE: electrical schematic for xas 56 atlas copco
whith serial number I can provide the wiring diagram
Posted on Jan 02, 2011
What does a JDEC warning mean on my XAS 375 Atlas Copco
Atlas Copco has used John Deer Diesel engines in the past, that could be a warning or code concerning the engine since it starts with JD.
Mar 09, 2018 | Air Tools & Compressors
Where do I get a spare parts manual for a Atlas Copco xas 160
The staff at www.aircompressordelmarva.com has all the manuals for atlas copco air compressors. You can email or call them. They posted an Adobe link for me for a really large one so I could download it. Very helpful. Delmarva Air Compressor Powered by Network Solutions
Nov 15, 2014 | Air Tools & Compressors
Xas125 atlas copco compressor
check with atlas or atlas dealer. I would be guessing but most labels include the capacity in the model. So xas is the model and 125 is the capacity in cubic feet /minute
May 09, 2013 | Air Tools & Compressors
I need a service manual for a atlas copco xas85dd 175cfm air compressor
necesito el manual de atlas copco del compresor de alta presion xas 175
May 28, 2011 | Air Tools & Compressors
Electrical schematic for xas 56 atlas copco compressor
Sep 20, 2010 | Air Tools & Compressors
My 1998 atlas copco xas 97 185cfm deutch diesel shuts down when i open full air
Nov 04, 2009 | Air Tools & Compressors
Excessive oil discharge
This is not a cd/dvd drive question.
Dec 02, 2008 | Kano Technologies Atlas (K752HCDR) DVD+R...
Air Tools & Compressors Logo
70 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
