Question about Video Game Consoles & Games
Psp 1008 charging problem - Video Game Consoles & Games
Vtab 1008 wont charge or turn on
your vtab must be hanged ,it fecced because you should bbe used more then time and it must be older otherwise you going to your nearby experts shop,they can fixed that.
Mar 26, 2013 | Vizio Tablet VTAB1008
I have a psp and i dont know if the psp is broken or is it my charger or battery please help!!!!!!! sony model psp-110 battery pack 3.6
Solution 1: Try to borrow from your friend psp charger and charge it if charging. this maybe the problem.
Solution 2. Try to borrow replace the battery if it will charge. This may be the problem.
Otherwise the problem would be the psp unit itself that you are using while at battery charging. Hence your are playing and moving, you have tendency to damage the charging port of your psp. This maybe the problem and need replacement of parts.
Dec 19, 2010 | Sony PlayStation Portable (PSP) Console
L want advice on the best bernina to buy, 1008 or 1010. what is the difference between 1008 and 1008S and 1008ES
The machines are the same, the only difference in the 1010 was made from 1989 to 1991, the 1008 in the new version! Both great machines!
Aug 19, 2010 | Bernina 1008
How to set my Bernina 1008 sewing machine up for sewing
That information is in the instruction manual that's available here:
Bernina 1008 Sewing Machine Instruction Manual
Dec 01, 2009 | Bernina 1008
I cant charge my psp with usb
go to settings and check that usb charge option is on... and ake sure its in usb mode
Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
It's a special bulb. Try a Bernina Dealer. I saw one the other day around $12
Mar 16, 2009 | Bernina 1008
Psp won't charge
check the battery or the charging cable is not inserted correctly or its cutted
Jan 26, 2009 | Sony PlayStation Portable (PSP) Console
Psp usb charging problem
ok a psp CANNOT in any way shape or form charge by using a usb cord.
so your kidding yourself if you think u got it to charge off of your pc in the first place.
but that is the problem you CANNOT charge your psp via usb
Dec 27, 2008 | Sony PlayStation Portable (PSP) Console
Charging a PSP
Sounds like it could be the mains/charger of the psp, have u tried using it on the other psp? If that dont work then it may be the power charging unit of the psp itself, u may have to call Sony and have it replaced
Hope it helps
Dec 10, 2007 | Sony PlayStation Portable (PSP) Console
Psp battery won't charge
Its a problem with the unit's charging will have to get it replaced it shouldn't cost you more than 10$..
Oct 27, 2007 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
