Question about Jura ENA 3 Automatic Coffee Center - Black
System is not filling in my Ena 3. Pump stalled despite several attempts to prime it. Any suggestion?
    New Friend:
  • 78 Answers
I do not know what efforts you made to prime the pump.
1- Make sure that the water faucet is open.
Use a hand pump to push water into the pump. You can use a syringe or a hand pump. See instructions attached. Services Unlimited Inc Parts Guru Since 1988
Posted on Dec 30, 2016
What is Wrong With a Stihl FS90R Trimmer When The Primer Bulb Won't Fully Fill After Priming?
1) check valves inside the primer plate is sticking
2) fuel pump diaphragm is varnished and flaps are sticking to the body of the carb
3) the cost of parts and time spent are more than a new carb
4) new carbs are updated versions and have updated ethanol resistant components
** suggest a new carb, it will solve several performance issues
Feb 19, 2017 | Stihl Garden
Continuous problems with starting car after filling gas. Seems it has to do with loss of vaccum since engine dies like there is no gas after starting until 3-4 time starting.
This problem is most often caused by a faulty/worn electric fuel pump inside the fuel tank, when you fill it up the gas is very cold, if the pump is worn from years of use the pump can seize up due to the temperature drop and repeated attempts to start are needed to get it going, or it starts and stall several times until it warms back up. Yes I have seen this in the real world, it is not a guess.
Jan 17, 2017 | Cars & Trucks
A shallow well pump needs to be primed. On the bottom of the well above the sandpoint there should be a foot valve (check valve) installed.
On the top of the pump there is a fill cap. Fill the pump until it is filled to the top. I
Replace the fill cap and start the pump. If there is air remaining in the well attempt a second time.
If the pump can not be filled it would indicate that the check valve is not working\ or the water level in the well is low.
cannot-get-new-pump-prime-old-pump-edcyhy51ohkznhh1wg1ly0d0-3-2.jpg Hope this helps?
May 17, 2016 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Won't spray water and cleaner from the machine
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Jan 24, 2010 | Bissell 9200 Upright Vacuum
Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
The machine lost it's prine and now we can't seem to get it to take a prime. We've tried several times and it won't take anymore water but when we attempt to make a cup, it won't push any water through. We...
For that one you might have to take the water hose that leads into the pump fill it with water and hold it up while running the hot water cycle to prime the pump.
Nov 14, 2009 | Saeco Gran Crema 2-Cup Espresso Machine -...
Priming problem
Make sure you try to prime right when the machine is turned on, so that there is no boiler pressure making it more difficult to prime.
Johnny C
Sales & Service
Oct 21, 2007 | Starbucks Saeco Italia Digital Barista...
Jura ENA 3 Automatic Coffee Center - Black Logo
Top Jura Coffee Makers & Espresso Machines Experts
ray gallant
Are you a Jura Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
