Question about Mitsubishi WD-73733 73" HDTV
I just replaced lamp on my Mitsubishi 73733 and need instructions on resetting timer
  • 1284 Answers
SOURCE: need to align my mitsubishi wd-73733 dlp tv
We TV technicians don't go into alignment unless absolutley needed. I would stray away from alignments period unless you understand all of the ramifications that come with them.
Posted on Jan 08, 2009
SOURCE: How do I reset lamp timer on Mitsubishi DLP TV?
I cant find the solution to reset my lamp hours, I replaced it, unplugged the tv like i was supposed to to. Its not reset. I have a 73" 1080p ...wd 73831 series
Posted on Aug 23, 2009
  • 52 Answers
SOURCE: How to reset lamp timer on mitsubishi wd-65734
This model there is no reset for lamp timer.
Posted on Nov 14, 2009
  • 128 Answers
SOURCE: Mitsubishi WD-73733 73 in. HDTV
Could be the ballast of your tv please check our web page so you can find it
Posted on Dec 18, 2009
  • 160 Answers
SOURCE: how to change lamp in mitsubishi wd 73733
Your TV is so-called V-36 chassis.
First shut off TV and unplug it from the wall.
On the back of the TV on the right hand side if look from behind you can locate plastic lamp cover that is removable. Behind the cover you will see lamp cartridge that held in place by screws that you have to loose using screwdriver. Remove lamp assembly and install the new one. Make sure that cartridge is all way in, you have to feel connection plug to be slide-in all the way. Tighten up screws but not too hard.
Reinstall lamp cover. Plug TV into the wall and wait for green LED light to stop blinking. Turn TV set on. It should display message "Power loss, did you replace the lamp?" You hit "enter" on your original Mitsubishi (not the cable box or Satellite box) remote control and this is it.
Posted on Apr 07, 2010
Mitsubishi 1080p dlp hdtv troubleshoot
If it's older. Probably a blown lamp. Check owners manual then shop,new one on eBay. Easy to replace. I have done it twice
Sep 27, 2013 | Mitsubishi Wd-73733 73-inch 1080p Dlp Hdtv
The operator's manual has no reference to a lamp timer. The only user setting associated with the lamp is "Energy" for setting the lamp power to Standard or Bright. I'm surprised; most LCD RPTV sets have a timer that should be reset after replacing the lamp, and the instructions for doing so are given in the manual. The manual for this model only says to replace the lamp if the picture is getting dimmer (page 77).
Sep 24, 2012 | Mitsubishi WD-60737 TV
I got a new bulb and housing and my t.v. still wont turn on...
If you do not miss anything when replacing the lamp try to reset the lamp hour meter, unplug your unit to the main AC outlet, then plug it again, then turn on projectors main switch. Hold down the two arrow buttons and the Power button on the control panel at the same time for 3 seconds. The status indicator will blink twice. The timer will be reset to zero hours. hope this may help good day and best regards.
Sep 16, 2011 | Mitsubishi WD-73733 73" HDTV
How do i reset lamp
Power on the projector. Press the left and right arrow keys and the power key on your remote to reset the lamp timer. The three keys must be pressed simultaneously to reset the timer.
Read more: Mitsubishi SL2U Bulb Replacement Instructions '
Dec 19, 2010 | Mitsubishi SL2U Multimedia Projector
TV will not power on, strange arcing and poping noise from rear
Even though the Lamp looks good it does not mean that it is. The only way to know is to relace it. If you have already replaced it with a Mitsubishi Lamp Assy. then the Ballast board would probably be the cause.
Hope this helps,
Jul 04, 2009 | Mitsubishi WD-73733 73" HDTV
Need to reset lamp timer
The lamp timer expiring would not shutdown the unit typically. Purchase a replacement lamp and included will be the instructions to both replace the lamp and reset the timer.
Apr 15, 2009 | Mitsubishi ES100U Multimedia Projector
Lamp replacement
The file is too large to post here but if you post your email address, I can send you the step by step instructions to replace the lamp and reset the lamp hour counter.
Mar 01, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Mitsubishi WD-73733 73" HDTV Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
