My machine is showing se
During washing, the machine stops after beeping twice and when we check its written SE.what is wrong
  • 1,381 Answers
SE also comes up as 5e
The '5E' Error is displayed when the water is not draining properly from the Washing Machine. If the water does not drain in 15 minutes, a buzzer will sound , and the remaining time indicator will show '5E' Error.
You can perform following steps to resolve the issue :
? Clean the debris filter.
? Make sure the drain hose is not clogged.To make it unclogged, Detach the drain hose from washing machine. Attach the spray nozzle to the end of the hose. Aim the sprayer into the clogged washer hose and spray water kinetically down the hose. Continue spraying until the hose is no longer clogged.
? Make sure the drain hose is not frozen.
? Make sure the drain hose is installed correctly.
Posted on Dec 16, 2016
Washing machine keeps stopping and SE shows
The error is SE/5E - drain error. The system is not draining properly. Problems could be the drain hose is clogged, the filter on the drain line needs cleaning (if you have one), or the drain pump is malfunctioning.
Aug 05, 2014 | Washing Machines
Have WD1295fb model with error SE , tries to start but fails ?
Check the door lock motor and switch assembly to ensure that the switch works correctly. Check with Ohm meter to ensure continuity when operated.
Nov 30, 2013 | LG WD-1295FB Front Load Washer
The display is showing se during the spin cyccle???
Hello there and than you for choosing fixya
LG error code SE LG washing machine error code SE indicates a "motor fault" although the code also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you are a DIYer unless you at least know how to test a motor for faults and check its connections.
Jan 25, 2011 | LG Washing Machines
SE error code on Samsung dishwasher - ...any suggestions?
This means that the Dishwashers has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the beeping sound, then try turning the Dishwashers off and on again.
If you still see the "
SE error code," turn off the power to your Dishwashers and wait five minutes before turning it on again. If you hear the beep or see the "SE error code" when you try to washing again, please call your authorized provider for service.
Hope this help?.
thanks for visit.
Dec 15, 2010 | Samsung 24 in. DB3710D Dishwasher
SE shows on the display
Water Sensor Error. You need to have this changed as it has failed
Aug 15, 2009 | Washing Machines
Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
Jul 22, 2009 | Brother SE-270D Computerized Sewing...
Error code se
can you check the temperature sensor , i know thats not the same fault , the fault to the sensor is be but check the sensor , at the bottom of the tub between the heather connections
Jun 18, 2009 | LG WM-2277HW Front Load Washer
Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Jan 16, 2009 | Samsung SW62ASP Top Load Washer
LG Washing machine - Front Loader
Suggestion: Check your outlet filter, it could be blocked. I looked for this SE could not find it.
Jan 15, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
