Question about Proscan Televison & Video
Having trouble connecting my Proscan plded4017 HDTV to my direct tv box.
5 Suggested Answers
SOURCE: connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Posted on Jul 15, 2008
tvtek
  • 1284 Answers
SOURCE: program remote to a direct tv reciever
You are most likely out of luck using these as universal remotes. You are better off purchasing a Logitech remote and programing it for the Polaroid and your Directv box.
Posted on Jan 09, 2009
budmrtn
  • 11361 Answers
SOURCE: ordered proscan 32LB30QD from Costco. The coaxile
Costco has very good return policy within 180 days, I would try to get the exchange unit instead.
Posted on Jan 06, 2010
  • 6 Answers
SOURCE: Can't get HD channels selected on tv. Tried auto search with HDTV port connected and the menu selected to HDTV
Hello, the HDTV input is what you would use if you were not using a cable box.
You should connect your cable from the wall to coaxial input on the cable box, and connect an hdmi cable from the hdmi output on the cable box to the hdmi 1 input on your tv and then switch the tv to that input.
Tommy, HD Installations
Posted on Sep 07, 2010
Proscan tv plded4017 changes color
Could you explain what you mean by changes colour, please?
Nov 29, 2017 | Proscan Televison & Video
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
How can I connect my DVD and my Direct TV Proscan HDTV to my Harmon Kardon AVR5 receiver
You didn't mention the model, but if it's a recent receiver it should have HDMI connections. You need two cables, one from DVD to receiver, the other from receiver back to TV.
Sep 23, 2015 | Audio Players & Recorders
How to turn off closed caption
Unplug your tv from the wall (AC Plug) for 10 minutes. The set should revert back to default settings. This can also be done to your cable box/ direct tv box/ dish box.
Jul 29, 2014 | Proscan 50" LCD HDTV PLCD5092A - CURTIS...
My 16 year old son found a Proscan 19LB30QD on the side of the road (good old country living) anyway, it has not plugs, it is probably broke, but we thought we'd give it a try and see if it works. ...
Do you mean that the unit has no power cord or is the TV missing the input board from the side? Sears Parts Direct has parts for the Proscan 19LB30QD here: http://www.searspartsdirect.com/partsdirect/part-model/Proscan-Parts/Television-Parts/Model-19LB30QD/3027/0333300/50036238/00001?blt=06&prst=0&shdMod=19LB30QD . The AC cable is PART NUMBER: E080515H00 for $27. There is also an adapter, PART NUMBER: E075WDN1, for $26.79. The input board is part 6 on the diagram (main board).
Other cords will depend on what you want to connect to the TV. There is 1 HDMI port for connecting a set top box, component, composite and S-video jacks (for other set top boxes), a VGA port and a coaxial (antenna jack). Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/19678/PROSCAN-TV-VCR-or-DVD-Combo-L0807673?brand_name_search=fall+back .
I hope this helps.
Oct 06, 2011 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
I just setup my 42" 1080p proscan tv I have Direct tv and can not get a signal.
Okay most settop direct TV boxes go into a coaxle connector in the back of your TV witch then your Tv would need to be on channel 3 make sure channel 3 is detected by autoscanning for it or undeleting it if its been deleted but make sure the direct tv box is on and running.
If you have them on the scant connectors make sure you on the right input on your TV control there should be a input button press that to scan through to find your direct tv box!
I hope this helps!
Jul 08, 2009 | Proscan 42LA45H 42 in. LCD TV
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan to Bang and Olauffson sound system
FDirstly, you should not connect your TV to a Sound System. If you desire to listen to your Broadcast TV , and enhance the listening experience,I suggest you use the Audio L & R outputs of your Cable Box to your Sound System AUX IN , and Video Out to the TV's Video IN socket. Then you will recieve a better picture and a enhanced sound quality. But just directly connecting the TV's Audio Out to the Sound System will make scarcely any difference.
Aug 20, 2006 | Proscan PS36600 36" TV
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
