Question about Hitachi Televison & Video
My Hitachi LE40K507 will not come on. I have tried all the power steps including unpluging and holding power button down.
All i have is red light when tv is off and it turns blue when on but no blinking lights. It did turn blue a bit ago but no picture or nothing
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
  • 1694 Answers
SOURCE: Mitsubishi WS65513 with blinking green light
Download .........T.
Posted on Nov 09, 2007
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
  • 121 Answers
SOURCE: Red light blinks
Check the lamp door (with green on) ,.. both green and red blink - bad lamp. Green off, red blinks..Try unpluging for 2 minutes and retry - if no different (sorry, call a service person).
Posted on Apr 21, 2008
  • 19396 Answers
SOURCE: toshiba 46H84 tv turned off light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
My led emerson 32 inch flat screen will not power on manually even! red light comes onand flashes 5 times then the red light just stays a solid red and the tv never powers on......nothing! tried 2 ways of...
It has gone into safe mode as an internal fault has been detected you need to take the back off to repair or replace board's up to and including the screen
Aug 15, 2017 | Emerson Televison & Video
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Prints multiple copies of job and will not shut off or stop printing
Unplug the power cord from the printer. Hold down the red "X" button. Plug the power cord back in while holding down this button. Release the button. Should see flashing red and green lights. Unplug the power cord again. Replug. Should be reset.
Apr 10, 2011 | Dell 1100 Laser Printer
Screen is black: eventhough the red power buttons on will not respond to power on button.
tv will not turn on. Red lights indicate power to unit, no change when on button is pushed. I have tried powering the unit down with the master power button and also unplugging the power cord from back of unit. No change
Aug 11, 2010 | Hitachi 26HDL52 26 in. LCD Television
Red lights flash alternately with no printing response
Hi Try to do a Powerflee
unplug all the cables including the power cable.
press and hold the power button ( On/Off) for 30 seconds
plug back all the cables and then try printing
May 07, 2010 | Epson Stylus Photo R200 InkJet Printer
Power light flashing and red light on button 2 will not print
Thanks for using FixYa. There are two step-by-step procedures to resolve the issue—
Procedure 1
  1. Turn off the printer and ensure that the print head is at its home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable for at least 20 seconds;
  3. While you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer’s power switch was ‘on’ - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds then release the button;
  7. The printer will now attempt to reset, including resetting the EPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  1. Turn off the printer and ensure that the print head is at it’s home location and locked in place as normal;
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete its processing then turn it off for a few seconds and turn it again on.
By following the above any one of the step-by-step procedure, the printer will start printing normally.
Please do rate the solution and revert for further assistance.
Oct 03, 2009 | Epson Stylus 680 InkJet Color Printer
Hitachi 50UX53K Ultravision will not stay on
The set is going into shut down mode for avariety of reasons. Some of the more common problems are vertical o/p ic bad connection or failure, poor solder connection usually in the power or hv section or possibly comb filter circuit breakdown causing 12V line to short. This set incorporate 7 or more shut down circuits and any one of them could be triggering - more trouble shooting is required
Sep 18, 2009 | Hitachi 50UX52B/53K 50" Rear Projection...
Have an hitachi 53uwx10ba red light on front is on but no tv
on some TVs, the lights do not turn off so that is not that big of a deal.  If you want to make sure, unplug the TV and then push and hold the power button for about 30 sec.  Then plug the TV back in and that should fix the light if it is stuck. (Pushing the power button wile unplugged will reset the system default!)
Nov 11, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi model 55ux58b
how many times does the light blink?
Dec 10, 2007 | Hitachi 55UX58B 55" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
