Honeywell th6320r1004 thermostat is stuck in connect wireless mode. Eig unit not reading thermostat and fan is stuck on. Cant exit set up wireless mode and hard reset wont work. Help please?
  • 2,760 Answers
How exactly did u preform the hard reset ??? U do know that u need to remove both the batteries and remove power to your heater (its connected too) for like one minute or more to properly preform a hard reset >
Posted on Dec 16, 2016
  • 1 more comment
  • Georgius O Dalaigh
    Georgius O Dalaigh Dec 16, 2016
    Ive removed the face of the and batteries for a minute, for an hour, and ive even cut the power to the furnace while doing this? Is this correct? Thanks for answering, btw.
  • J.D. Browning
    J.D. Browning Dec 16, 2016
    if I remember there are two AA batteries in the back section (wire compartment ) that need to be removed
    Yup, removed the batteries, have done all the easy tricks. Had to be terse in the op as per 200 charactwr limit
2 Suggested Answers
  • 3368 Answers
SOURCE: I changed my wireless setup and router, now the thermostat says connection lost, I followed the instructions to reset but the WiFi set up doesn't come up How do I reset the Wifi I have the RH
Be sue the router is on and is not blocking it.
Posted on Dec 18, 2014
How do I cancel schedule on Honeywell Thermostat TH6320R1004 and operate manually
https://customer.honeywell.com/en-US/Pages/Product.aspx?cat=HonECC+Catalog&pid=TH6320R1004/U
There is an owners/installation manual at this link. Option #16 shows that it's a programmable only tstat. You don't have an option to remove the programming. Hope this helps!
Mar 31, 2017 | Honeywell Heating & Cooling
Honeywell tstat not working in auto cool mode
so with system setting cool/ fan setting auto, the condenser runs but the indoor blower does Not? but when system setting cool /fan setting on, the condenser runs and the blower runs?
Oct 25, 2017 | Honeywell Electronic Programmable...
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
Assuming you have the fan switch of your thermostat in AUTO, it sounds like a stuck Fan Relay. If the fan relay is stuck, your fan will continue to run as long as there is line voltage being fed to your unit. This relay could be an independent component or it could be an integral part of your control board. Have an experienced, qualified service technician check it out.
Mar 19, 2010 | Honeywell Programmable Thermostat Heater
What is the best cost effective thermostat to use
with every one screamming the same two songs today. I want both effiecancy, and comfort, for years we have scarcrificed one for the other,,, thanks to HONEYWELL we can have both.
The new wireless zone system allows for mobile zonning, where you are its comfortable.
Your t-stat roams around the house with you,
Ensuring what ever room its in, will be the temp you set,,,,
I know i sound like a salesman, but it is honestly what i reccomend to all my customers from the day it hit the market lst year....
The directions that come with it make the insatllation easy enough for a geico add man
it is al lil more expensive in the beginning I agree
but you asked for cost effective, and in my mind it is the most cost effective unit on the market.
-Honeywell TH6320R1004 Programmable Wireless Thermostat
i do hope this helps
Oct 29, 2009 | Heating & Cooling
Honeywell Wireless System THM5320R Wireless system and thermostat startup ok. The issue I am having is that; when the thermostat is in cooling mode and the unit starts the reversing valve is in the wrong...
make sure you thermostat o terminal is used fir reversing valve in cooling, or b terminal is used if unit is a Rheem or Rudd, reversing valve at condensing unit may have bad connection.
Oct 28, 2009 | Heating & Cooling
Air conditioning won't work. Thermostat says it's in 'recovery mode'
by the outside unit, you will have a shutoff. pull out the shutoff, and unscrew the cover. 2 cylinder like fuses are inside. It is likely that one or both are bad. When you turn on the AC and the outside fan does not turn on... this is likely this is the solution.
Apr 28, 2009 | Honeywell Electronic Programmable...
Rth230b thermostat, want to change C* to F*
Turn the thermostat mode to off. Push & hold both temperature up &down at the same time and screen on tstat should change and display Unit this is where you change C to F setting. I dont quite remember how to exit, if you change your setting and leave tstat alone and it should change automatically Good luck
F
Jan 08, 2009 | Honeywell Programmable Thermostat Heater
Honeywell digital thermostat won't turn off ac.
The Honeywell CT87 thermostat is a normal round thermostat, not digital and may have a sub-base installed with it that has a two switches on it. One is for Fan (Auto or On)and the other is for Heat, Cool and Off. Make sure the Fan switch is in the Auto position and the other switch is in either the Cool or Off mode. If you continue to get cooling, you have a short in the thermostat wire or a stuck relay in th indoor or outdoor unit. To test this, while the unit is running; remove the round outer ring on the thermostat by pulling it straight off towards you. You will find 3 slotted head screws that hold the thermostat to the sub-base. These screws are located at the 3 o'clock, 7 o'clock and 9 o'clock positions. Turn these screws counterclockwise with a small head screwdriver. They are held in place so should not fall and get lost. With the front of the thermostat removed from the base, the air conditioner should stop running. If the unit continues to run, you will need to have your A/C system inspected by a technician. If in fact your thermostat is digital, look to see how it is mounted to its sub-base and remove it. If the system stops, you may have a bad thermostat or the Fan switch is in the On position. Hopefully this will help.
Sep 11, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
129 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
