Question about Toto Home
Can Toto promenade toilet have a different tank
arealplumber
  • 33 Answers
SOURCE: Toto GMax Flushing System drips
What you are experiencing is a flapper valve problem. Since I don't know what model you have I will give you a link to the generic GMax unit. Here is the parts breakdown for a GMax
Toto GMax
I would suspect you need part #7 on this diagram a flapper valve. Take the old one with you since different colors ones are used on different models. You should go to the Toto site to locate a dealer first. You can find their site here:
Toto USA
Hope this helps and please remember to rate this!
Posted on Dec 09, 2008
  • 14 Answers
SOURCE: Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Posted on Jan 10, 2009
gypsycat00
  • 224 Answers
SOURCE: Once my tank has filled (toto toilet) the fill
The fill valve isn't adjusted correctly. Does it have a ballcock or a newer fill valve? If it's the ballcock, there's a screw in the middle of the fill valve that you can loosen to lower the ballcock. If it's newer, you'll see a float that surrounds the fill valve. It has a small metal clip toward the bottom that you need to pinch to raise or lower the float. It also has a large plastic screw with a phillips head at the top for fine tuning.
Posted on Jul 04, 2009
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
bearsfan7538
  • 119 Answers
SOURCE: need diagram of toto toilet tank inside have
You need to replace the fill valve
Posted on Nov 15, 2009
My toto power gravity siphon won't stop running. Suggestions as to how to fix would be greatly appreciated. Cheer, Mark
You have a problem with your flapper not seating all the way so the water is not filling in the tank to lift the ball **** to shut off the water first make sure the flapper is ok
Oct 24, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toilet bowl water keeps running eventhough flushing already finished or eventhough water in the tank already full. Model CST414M (elongated TOTO toilet). I appreciate your immediate assistance.
Look at float level, be sure that you are not running water into the overflow tube. Is the inlet valve closing? Pull the little tube that goes from the inlet valve assembly to the overflow tube and observe... Check the flapper valve for distortion, deterioration, or buildup. If anything is there, replace it.
Sep 26, 2010 | Toto Promenade, 1.6 GPF, Elongated...
The water in the bowl keep runing after the tank is full.
fill valve not shutting off water running over overflow tube set or replace fill valve flapper valve leaking replace flapper valve cracked and leaking flush valve assembly replace
Sep 18, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toto Dorian toilet does not flush clean
Don't know if you have calcium build up problems. If you do you could pour a calcium cleaner into the tank to try and clear up the problem. This would be the only way to possibly clean the enclosed area. Good Luck. Jeff
Apr 05, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toto toilet keeps running. water is going into the pipe continuously.I am stupid about fixing this.....or anything.....any SIMPLE help? thanks
Turn of the feed line for the water. Flush the toilet. Then reach in tank and pick up the flapper valve. Clean around the seat of the flapper valve real well. Check for damage on the flapper valve and clean it as well. Put the flapper valve back in its seat and turn the water on to fill the tank. Then bend the rod for the float down a touch. This will put more pressure on the water valve at the top of the pipe in the tank. If this doesn't work, you may need to change your float valve. They wear out. The ones you buy in the DIY stores generally have diagrams and good instructions for installation.
Jan 17, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toilet bowl does not have enough water. its the 1.6 gal. is there a way to adjust the water level? Toto
It depends on the design. Some of these have a flapper with a hole in the cylinder on the bottom side. Watch the flapper as you flush normally. You will see a few bubbles come out of the hole and the flapper will drop before the tank is empty.
If this is the case, you can plug the little hole with something, or buy a new flapper without the hole.
Dec 19, 2009 | Toto Promenade, 1.6 GPF, Elongated...
My toto toilets do not fuush consistently...why?
there are numerous reasons that could cause the problem. If you are having any kind of problems with the sinks or tub/showers draining...then I would say it is either a venting problem or an actual moving blockage in the toilet or drain lines. Check to make sure the water level is where it is supposed to be when you flush. The toilet actually works on downward pressure that is provided by the amount of water in the tank. Also if the flapper is closing to soon that could cause the problem too. Just so many variables.
Oct 17, 2009 | Toto Promenade, 1.6 GPF, Elongated...
Toto toilet Power Gravity intermittently running
I suggest that you replace the cap with the new seal, it sounds as tho the valve is not shutting off and the bowl fill tube continues to run. Have you adjusted the water level to 3/4 of an inch below the overflow tube. If not, try that.
Mar 16, 2009 | Toto Promenade, 1.6 GPF, Elongated...
Home Logo
54 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
