Question about Vacuums
Water squirting out flow indicator - Vacuums
After replacing pump water comes out in short squirts. It seems to come out of pump in steady stream but short squirts at nozzles including hand held.
Check your filters. Flow Indicator Filter: Turn Flow Indicator Cap counter-clockwise to remove, lift rotor and filter out. Clean filter and replace in reverse order.
Sep 03, 2015 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Cant squirt water, nothing is coming up from the carpet
Try filling soap solution tank with hot water and make sure that the red filter in the pickup tank is not clogged, and always run hot water in solution tank after cleaning carpet. steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
No water spraying
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Aug 10, 2008 | Bissell Vacuums
Bissell 1699 not dispensing water
Jul 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
I have a bissell proheat clearview plus steamcleaner. i was using it and then the little red flow indicator stopped spinning and it quit sprayng any liquid. i looked for where it could be clogged but i...
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
May 01, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissel pro heat turbo. I beleive it is clogged with ahir and fiber. i don't see water going up through the front How do I unclog
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad.
Apr 24, 2008 | Vacuums
Bissell Powerwash Proheat, flow indicator not rotating
Is it spraying? Is so, maybe the cap for the indictor can be too tight, or loose, maybe be bad and allowing an air leak. The white filter under the indictor may need to be cleaned. If no spray:
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and mater thru it to see if it will unclog it.
No water spray
Does water shot from the hose when you depress the trigger? If it does, then the heater in the handle may be clogged and will have to cleaned out or replaced. If no water squirts out the hose, then check the bottom of the bucket, make sure the gasket or seal is on the auto-load on the bottom of the bucket and not in the hole. The red flow indicator cap may be loose or leaking air. Could have a clogged or pinched water line under the top housing.
Jan 31, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell water not working
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
Oct 21, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water
That red thing is most likely the float asm Part #2140325 .
Oct 17, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
