Our Bosch does the same thing, we just open the door shut of the power and close the door again so the heat can sanitize the dishes. I don't recall if there is an alert off button though.
The Self-Help section in your manual states you can adjust the volume or deactivate the beeping signal. Instructions on how to do so are supposed to be in the "cycle completion signal" section of the manual which it appears the tech writers forgot to include in the published version of the manual. I have not worked with this particular model so your best option now is to call their customer service number and talk to someone that knows how to turn it off. FYI, their customer service phone number is 800-944-2904.
Hello Craig, You can use Affersh dishwasher cleaner (link here) http://www.affresh.com/our_products/affresh_dishwasher_disposal_cleaner and to achive "Super hot" wash you can reset your hot water heater to a super high setting and the run a few cycles of the dishwasher....once done be sure to reset the hot water heater to the usual setting...also a very effective cleaner in the dishwasher is white vinegar ,try that along with setting the water heater higher
To turn the volume down of the signal or to turn it off entirely is as follows...
Hope that solves your incessant beeping problem. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided here as well as a brief testimony is appreciated.
It sound like a pump issue.
Open the service panel, remove the pump and try to rotate its pulley manually, it should turn freely.In case it doesn't,check if it is clear from any foreign object or it should be replaced.
Good luck !
