Question about Sewing Machines
Computer stuck on industrial machine after moving it
    Top Expert:
  • Sewing Machines Master
  • 8,302 Answers
  • 2,760 Answers
If your saying your industrial sewing machine has its control screen frozen since you have moved it , you will need to leave it disconnected from mains power for over an hour then reconnect it this should un freeze the display unless its got a more serious problem , but most times this produces some error codes as well
Posted on Dec 16, 2016
When i release the leg lever to let down the presser foot ,the foot wont release all the way and now it wont stitch
Mine does this too sometimes. Lift up the head and look in the middle of the oil pan. The knee controller runs through there. Make sure the black knob is not stuck. Hit the knee thing a couple of times to make sure it is not stuck. It should move freely up and down. That may fix the problem. If not, look st the small post to the left and behind the oil intake. Move the manual presserfoot lever on the machine to see it move. It will be stiff, but it should still lift a little. Usually jigging these two parts will fix the problem. Good luck..
Mar 22, 2016 | Juki DDL-5550 Industrial Straight Stitch...
How do i free a jammed sewing machine wheel
oh, there has got to be a reason. Is the needle stuck down, did you take the bobbin case out? Is the belt tight enough to move the wheel? need more info
Aug 10, 2014 | Brother Industries, Ltd Brother Sewing...
How do I get a Service manual for an Industrial Sewing Machine
If the handwheel is really stiff and the machine is making awful noises, then your machine may need oiling. Don't know if this is the case with your industrial machine, but it may be something to consider.
Jun 12, 2014 | White Sewing Speedylock 1600 Mechanical...
I need information on tension disk for Juki 1541-S Walking Food Industrial Sewing Machine
Get a magnifying glass and look carefully at the disc for a build up of wax and burrs. You may need to clean them up or use a piece of fine sand paper to remove burrs. Start there.... then if no improvement seek out your local industrial sewing machine repairman to get parts and further help.
Oct 14, 2012 | Juki DNU-1541 Mechanical Sewing Machine
I have a bernina 740 semi-industrial it just came to a halt and wont move
check with bernina to see if the machine has a hidden fuse & if it doesn't then the machine needs to be serviced
May 19, 2012 | Bernina Sewing Machines
Singer industrial tacking machine model 269W8 Having tension problem because of the tension discs....threads get stuck in there no matter how I try to adjust it...and right now I am having that...
Maybe, you can try, rethread, now with the presser foot up, pull on the top thread, it should pull smoothly, then lower the presser foot, pull on the top thread again, it should barely move. This sometimes will seat the thread in the tension discs. Hope it works for you, otherwise you will have to have it serviced by a professional
Nov 23, 2010 | Singer Sewing Machines
Brother cs 6000 bobbin moves
Try this for me clean out the hook area under the bobbin case some times dust from thread and cloth build up under the bobbin case and it can push up the bobbin case and cause the same thing to happin.
Oct 18, 2009 | Brother CS-6000
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
