How to operate tromm dd inverter 10kg wd tr101p washing machine
4 Suggested Answers
michiganfan9
  • 179 Answers
SOURCE: NO SPINNING NOR DRAINING LG TROMM SER.WD-12210DB 10kg
check your pump to make sure that it is clean there is a door on the bottom of the machine open it use the little hose to drain the washer in a bucket then twist the big cap and pull it out clean that trap
Posted on Dec 26, 2008
drsn
  • 42 Answers
SOURCE: TROMM Washer "CL" Error Message
THE CL ERROR CODE IS CHILD LOCK, PRESS AND HOLD THE PREWASH BUTTON FOR 3 SECONDS AND IT SHOULD TURN OFF........ BUT IF THERE ARE OTHER BUTTONS TO PRESS TRY IT OUT, THE OLDER LG'S HAD TWO BUTTONS TO PRESS, SO IF YOURS ARE THE OLDER ONES TRY IT OUT..... IF THIS HELPED OUT, PLS LEAVE A FEED BACK. I DO NOT ACCEPT PAYMENTS FROM ANYONE ONLY FEED BACKS, IT MOTIVATES ME TO HELP OUT OTHERS WHO NEEDS HELP....................
Posted on Feb 13, 2010
  • 867 Answers
SOURCE: got a tromm dd inverter 10kg washer dryer and need a diagram or something on how to work it cause its in korean
There are no manuals available in English, maybe some in Korean but hard to find, What is the specific fault? I have had experience servicing these machines.
Posted on Mar 07, 2012
I need the Instruction Manuel of DD Inverter 10 Kg
Try Googling (trom)(WD-R107P)(manual) without parens.
Feb 17, 2018 | Washing Machines
I Av hoover washing machine silent pulse inverter 10kg 16000rpm and it keeps saying eq7 fault
I'm sick of this wm I rely on it for my bedridden 91 year old father it's broken down 4 times in 18 months ..I'm crying in the middle of a kitchen full of water
Aug 02, 2014 | Washing Machines
Got a tromm dd inverter 10kg washer dryer and need a diagram or something on how to work it cause its in korean
Mar 07, 2012 | Washing Machines
Lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Dec 15, 2011 | LG Washing Machines
Jun 24, 2009 | LG WM2688HWM TROMM SteamWasher
LG Tromm WD R8012 Owners manual
GO TO THIS SITE AND LOOK FOR YOUR MODEL NUMBER UNDER WASHERS. http://www.lge.com/us/support/product/support-product.jsp GOOD LUCK.
Jun 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dec 26, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
May 22, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
