Question about Ovens
All four hot plates on oven top heat up to full temperature when they are turned on. There is no low or medium heat. Can this be fixed please?
gil1714
  • 4 Answers
SOURCE: The hot plate is heating up when the selector is in off position
Hotplate heating up when regulator/selector switched off. Hi ,this is gil1714 in Scotland. Two possibilities on this one, 1) the regulator is faulty:- replace
2) if the control circuit (regulator) is wired on the neutral side the hotplate may be leaking current to
earth, thereby completing the circuit. This would only occur on a supply that was not protected by
an RCD. If so replace hotplate. Hope this is useful,
Posted on Dec 16, 2008
barkencoa
  • 3463 Answers
SOURCE: oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Posted on Dec 27, 2008
  • 21 Answers
SOURCE: Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Posted on Jan 13, 2009
jumptrout51
  • 3361 Answers
SOURCE: burner heats up really high sometimes, even on low or medium
Replace the surface element switch for that burner.
Posted on Feb 22, 2009
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Fisher and Paykel Paprika Oven Top Elements Full hot!!
    No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
    Mar 17, 2012 | Fisher and Paykel Ovens
    My Maytag MGR5750ADW oven will take forever to preheat. It does get hot, but the preheat light takes a very long time to go out. Food takes much longer to cook as the oven does not seem to get up to temp.
    Hello there and welcome to fixya
    When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
    Aug 10, 2011 | Maytag Ovens
    Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
    If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
    Built in oven won't get hot
    hello there
    Usually, when an oven won't heat up or bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. Now if the oven It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem
    Hope thisis very helpful for you
    Best regards Michael .
    Mar 08, 2010 | Ovens
    Oven works but wont get up to temp
    When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.-----
    thanks for using fixya,please do rate the solution positively.
    Feb 17, 2010 | Magic Chef Ovens
    Oven 150 degrees off
    hi . i can help.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • Jun 23, 2009 | Ovens
    My oven turns off on me after only a minute never heating up fully
    Could be caused by either of following;
    1. Faulty thermostat.
    2. Faulty thermal cut out switch. (controls power to cooling fan).
    3. Faulty cooling fan (not fan inside oven).
    Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
    To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
    When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
    If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
    Jun 19, 2008 | AEG B1180-4 Electric Single Oven
    WHY WON'T MY OVEN HEAT UP?
    Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
    Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
    Ovens Logo
    46 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
