Question about Vizio VW22L VW22LHDTV10T 22 inch LCD HDTV HDMI VGA
VW22ldhtv10t please wait then goesw to black screen no audio no screen why and ghow do i dfix it
DX-L22-10A quickly shows "please wait"
Contact DYNEX for assistance (Mexico) Be patient...(siesta time...) They will talk you thru a RESET !! (I hope...)
May 03, 2011 | Dynex DX-L22-10A 22 in. LCD TV
I have a 19" StarLogic FTf LCD monitor that comes on for a second and the goesw blank.
wallybanq, All Cold cathode fluorescent lamp back-lit monitors use same basic design and principle of operation!!! Your unit no different. Do you know how to evaluate monitor internal power supply status with aid of bright flashlight?? You will porbably need to investigate and repair the "switch-mode-power-supply" internal to the unit. Read fixya profiles of "budmrtn" "buddymc" "12fixlouie" for DIY repair info. Some "black screen of death" units can be repaired for less than $8 if you have or can borrow a 40 watt soldering pencil and some solder. Also check out the video clips at YOUTUBE. Also check out this site: www.badcaps.net Once you know what it is that makes the FIXYA web page "white", then you will know just how similar those new "curlieQ energy efficient, CFL light bulbs work. Good luck with the repair. 12fixlouie
Sep 16, 2010 | Star Logic 17" LCD Monitor
Dynex L26 10A purchased little less than year ago has audio, but black screen. When first turned on screen will display: "Please Wait", then screen goes black, but audio can be heard. Tried uplugging from...
Call for warrenty serviced,u still have warrenty inforced until a year.Ur tv have intermittently signal shutdown before it come throught the Tuner board not,carrying to the LCD Screen to produced a picture.
Jul 03, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
When switching laptop on the screen goesw blue with a error sign even when trying to do a system restor it does the same after putting f8 then repair your comp
The blue screen of death is commonly associated with memory problems.
If this is happening outside of running windows, the you either have faulty Ram or a faulty motherboard. Have you overclocked the machine? Try setting the bios back to factory defaults. Try resetting the CMOS on the motherboard. If you have more than one memory module, take them out and try one at a time in each slot.
Looking on the upside, maybe it's time to upgrade... motherboards and ram have never been cheaper!
Jan 09, 2010 | Computers & Internet
No Video but have Audio
I found my product manual and called the Tech Support line. They said it was a problem with the display and would have to schedule and appointment to fix it.
Jun 19, 2009 | Dynex DX-LCD32-09 LCD TV
Fault shorted H2O sensor??
the sensor goesw into the header unscrews with two black wires
May 02, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Help with Pioneer Elite Pro-1130HD 50 inch
just wait it, because it is processing the display data
Nov 16, 2008 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Protron LCD TV
Try resetting the ee-prom in sub menu
Sep 30, 2008 | Televison & Video
PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Vizio VW22L VW22LHDTV10T 22 inch LCD HDTV HDMI VGA Logo
56 people viewed this question
Top Vizio Computers & Internet Experts
justwinwin
Are you a Vizio Computer and Internet Expert? Answer questions, earn points and help others
