Question about Admiral Washing Machines
Admiral ATW4475 Left by prior owner of home. Unpleasant Odor of moistness / mildew? / gunk emanates from tub despite careful cleaning including the inside rim. What should be checked and cleaned?
  • Admiral Master
  • 16,974 Answers
The basket / inner tub is actually what you see when you look in the unit. The inner tub connects to the transmission and sits inside the outer tub. Unless you take the whole top off and remove the inner basket, it is almost impossible to clean the outer tub. You can try to use the oem cleaning method and this is to run it with no clothes, on the hottest setting with one cup of bleach in the water.
Posted on Dec 16, 2016
Our admiral 7005l washer has a build up of black gunk around barrel , any ideas?
Mildew because you are using to much soap. The mildew hangs in the extra suds in the washer and feeds on the skin and food removed from your washing the clothes.
Mar 14, 2015 | Admiral Washing Machines
I just want an owners manual for my LG WM2010CW. We bought our house with this great washer, plus I have a mildew smell I can't get rid of
Sorry to say but the mildew odor is from excess use of detergent. The only way to truly get rid of it is to have the tub assembly torn down completely and cleaned out. Also replace the front door seal gasket to truly get rid of everything.
For temporary, you can use a chemical treatment called Whirlout or Affresh to mask out the odor but it won't totally get rid of it.
Good luck.
Jul 16, 2011 | Washing Machines
My Neptune washer leaves an odor in my clothes
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!^^^
Jun 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Mildew odor. We have followed directions in the manual and the problem persists. We removed the front panel of the machine and cleaned the white tube that was filled with "gunk," removed and washed the...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Apr 29, 2010 | Kenmore Elite 45986 Front Load Washer
Odor in washer tub
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%
Apr 05, 2010 | Speed Queen AWS45NW Top Load Washer
I have a Bosch WFMC 6401 UC front loading washer. Laundry is coming out with an unpleasant odor. There is nothing stuck in the seals at the door opening. My guess is that the filter needs to be cleaned....
Mar 12, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Very unpleasant odor in LG front-loading washing machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@!!
Jan 27, 2010 | LG WM-2277HW Front Load Washer
Odor coming from inside washer
There is a tub beyond the tub you see. Run a load of water with chlorine bleach. This will kill the mold & mildew spores that are causing the odors. ****Do NOT add clothing to this washload****
If possible, keep the door open when not in use. This will allow the inside to dry and mold & mildew cannot grow.
Jul 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
MILDEW ODOR IN MY HE3 MACHINE
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Washer Odor
Meoser,
I've been selling the only available all natural washing machine and towel mold and mildew remover online at smellywasher.com since 2006.
It's now also available at Ace, Tru Value, Hardware Hank and Do It Best hardware stores. One bottle provides 24 treatments and guarantees to remove mold, mildew, or any odor from your washer. After the washer is cleaned it also safely and easily gets rid of the mildew smell from any towel or clothing that the odor has transferred to.
The dark, moist environment of your clothes washer is the perfect place for mold and bacteria to grow. See: http://www.cbsnews.com/video/watch/?id=5408971n
We can't change that environment but we can stop the food source for them to grow buy reducing the amount of detergent used and stopping fabric softener use. Go to the blog page at smellywasher.com to read advice on the cause of and cure for washing machine and towel odor.
Nov 06, 2007 | Washing Machines
Washing Machines Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
