Question about Shark Vacuums
I have a shark superior carpet and bare floor cleaning, the bar does not spend as fast and it sounds weaker, can you tell me whats wrong, just bought it this summer 2016...please help..
  • 2,760 Answers
With use the beater bar (thing that turns) gets built up with lint from carpets and other items , this will need to b hand cleaned off every 20 hrs of use especially at the ends where pivot bearings are located also every 50 to 70 hrs of use the drive belt (rubber) for this beater bar will need to be replaced as well
Posted on Dec 16, 2016
Shark rocket ultra light
Hello, this is Ava with Think Crucial.
Your Shark vacuum is equipped with a motor protective thermostat. If for some reason your vacuum overheats, the thermostat will automatically turn the unit off. Should this occur, you would need to restart the motor thermostat. Turn off your unit and unplug the vacuum from the power. Clean the filters and dust cup filters. Check for blockages in hose, accessories and inlet openings. Then allow the unit to cool for a minimum of 45 minutes before plugging it back and turning it on.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 17, 2016 | Shark Rocket Ultra-Light Upright Vacuum...
I have a Dyson dc17 I have changed the belt cleaned the brush bar clean the bar motor reset the switch and still when i vacuum the brush bar just stops does not rattle. does not do it on bare floors or...
hooked rugs produce the highest amount of friction opposing the brush rotation, which can over heat the drive motor. try using a height setting that raises the brush so that it barely touches the pile. If this issue has been going on for some time, you may need to replace the drive motor.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson dc33 troubleshooting
make sure it's not on the wrong setting it needs to be on carpet and not floor settings
Jul 28, 2013 | Vacuums
My problem is a non woking beater bar on a UV 410 Shark vac.
none fixya is aware of
if you have pets or long hair . it is possible there is hair around the shaft or beater bar and it is sometimes really hard to get all of it of .
Jan 08, 2018 | Vacuums
I followed your directions to replace the belt on the Eureka Smart Vac 4870 upright bagged vac -- worked perfectly. Except when I turned it over and started using it -- the vacuum was in...
Obviously something is wrong. Take it to a vacumn repair shop and get it done right. The few dollors is not worth the frustration.
Mar 02, 2017 | Vacuums
Stripped gear noise occurs in carpet mode, not bare floor mode
Maybe the level to carpet is too low or there is more then one belt and one is broke?
Mar 26, 2017 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The knob that turns it from carpet to bare floors makes the head not spin for carpet It was a reburished one. bought in Nov 09
sounds like those wonderful people over at dyson installed the clutch and cover on wrong. it should be fine just use it oposite.
Dec 30, 2009 | Dyson DC07 All Floors Bagless Upright...
My dyson vacuum brush bar will not rotate and the belt is not broke. The hand tool works fine. What is wrong?
I took the plate off and cleaned up the vacuum brush bar. Since the belt was not broke I knew that was not the problem. I know when the setting is bare floor, the brush bar will not rotate. That was not the problem. I just keep turning the knob from bare floor to carpet, several times. The setting must have been "off" just a bit because after several times turning it, it must have reset in the proper setting. The brush bar did start rotating just like normal.
Nov 21, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Kenmore Vacuum 116.36623501 does not stay on bare floor setting
It sounds like there is something wrong with the latching assembly. GO to the Sears Parts website and enter your Model number. Look at the parts assembly for the Nozzle, and the problem will be in one of items 12 through 17.
Dec 27, 2008 | Kenmore 25512/ 25513 Progressive Canister...
DC07 bottom brush does not rotate.
I can not pinpoint what exactly solved the issue. I opened the bottom conver, cleaned any presence of hair, cleaned all hoses (yes hose was completely clogged), made sure that the brush bar was engaged by switching the selector back and forth few times from Carpet to Bare floor. (On bare floor setting, brush bar won't rotate).
Now I am happy that the vacuum is completely cleaned and back in operation!
Nov 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
42 people viewed this question
Top Shark Vacuums Experts
JoeVacs
Thomas Perkins
Thomas Perkins
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
